xilinx-zhaosheng
I can't find "AXI4-Lite to JTAG" IP in vivado 2015.4
xapp1251-xvc-zynq-petalinux.pdf
florentw
Hi @xilinx-zhaosheng,
The ip is in the ip repo folder in the .zip file for the xapp.
You might need to add the ip repo directory to the list of repositories in vivado
Hope that helps,
Florent
Florent
