luluzhang
I cannot find the settings.sh file in /opt/Xilinx folder after installing petalinux
after execute the following commands,
ardeal@ubuntu:~/xilinux$ mkdir -p /opt/pkg/petalinux/
ardeal@ubuntu:~/xilinux$ chmod 755 Xilinx_SDK_2018.2_0614_1954_Lin64.bin
ardeal@ubuntu:~/xilinux$ chmod 755 /opt/pkg/petalinux
ardeal@ubuntu:~/xilinux$ ./Xilinx_SDK_2018.2_0614_1954_Lin64.bin /opt/pkg/petalinux/
I got the following files in /opt/Xilinx  folder:
DocNav  Downloads  SDK  xic
I am going to run the sh file ./settings.sh, but I cannot find the settings.sh file in /opt/Xilinx folder.
Thanks and Best Regards,
Ardeal
luluzhang
Thanks!
I found that file in the folder you mentioned!
Many thanks!
senkoo
The settings64.sh file is located under: /opt/Xilinx/SDK/{your_Xilinx_version}/settings.sh
luluzhang
Thanks!
Many thanks!
