Hamidshafaghi
I don't have board support package for product of Trenz Electronic
Hi my friends
I use product of Trenz Electronic (TE0720) for petalinux and I did not find BSP file of TE0720
In tutorial for petalinux use BSP file . Is there a solution to this problem?
Hamidshafaghi
Trenz electronic provide PetaLinux template projects instead of BSPs for our modules. This template is included in our reference design in the subfolder (os/petalinux).
They are available on our download area.
This file isn't .bsp . This format is .sh .
We can lookup for instructions on: PetaLinux KICKstart
Thanks to Technical Support trenz electronic
Nikhil_Thapa
Hi @Hamidshafaghi ,
Can you check this link?
TE0720 - GigaZee - Public Docs - Trenz Electronic Wiki
You can also post your issue in Trenz Electronic GmbH Support Forum .
Hope these might help you.
Thanks and Regards,
***Do not forget to Accept as Solution, give Kudo and Share***
nikhil@logictronix.com
:::::Do not forget to Accept as solution, give Kudo and Share a post that you think is helpful:::::
Hamidshafaghi
