Visitor hfeng2016
I2C access lost after reprogram PL
I have a Linux kernel 4.0.0 build by petalinux 2015.4 running on Microzed(ZYNQ7020), with an AXI_I2C controller in the FPGA PL, the I2C access from linux works fine after fresh reboot. But if I reprogram the PL by dump the same bit stream to devcfg from Linux, I lost the I2C access. I also have AXI_GPIO within the same PL, the GPIO access works fine after reprogram the PL.
Anybody have experience on this issue?
Re: I2C access lost after reprogram PL
Hey @hfeng2016,
... if I reprogram the PL by dump the same bit stream to devcfg from Linux ...
Double check that it is actually the same bit stream you are sending to /dev/xdevcfg as was loaded during Linux boot. Also make sure to re-initialize the AXI IIC driver (e.g. unload and reload the kernel module) to accommodate for the now reset PL hardware.
Hope this helps,
Herbert
Visitor hfeng2016
Hi Herbert,
I'm pretty sure it's the same bit stream.
How do I reinitialize the I2C driver? apparently lsmod doesn't return anything under linux-xlnx.
Henry
Hey Henry,
You probably need to build the kernel driver as module to do so.
Make sure that the kernel is built with module support and that /proc is mounted.
Hope this helps,
Herbert
