I2C support in u-boot 2020
I'm trying to port a reference board bsp based on zcu102 from 2018.1 to 2020.1.
I'm facing the following error in u-boot (2020.1):
NOTICE: BL31: v2.2(release):v1.1-5588-g5918e656e
NOTICE: BL31: Built : 01:58:17, Aug 18 2020
zynqmp_clk_get_peripheral_rate mio read fail
failed to get rate
failed to get rate
failed to get rate
failed to get rate
failed to get rate
No serial driver found
resetting ...
My I2C setting in u-boot config are:
# I2C support
CONFIG_DM_I2C=y
CONFIG_I2C_SET_DEFAULT_BUS_NUM=y
CONFIG_I2C_DEFAULT_BUS_NUMBER=0x0
CONFIG_SYS_I2C_CADENCE=y
The answer https://forums.xilinx.com/t5/Embedded-Linux/Petalinux-15-4-Add-I2C-support-to-u-boot/td-p/853882 also has same issue but the I2C settings uses CONFIG_SYS_I2C which is not working for my 2020 build. (CONFIG_SYS_I2C and CONFIG_SYS_I2C can't be defined together).
Any pointers to what am i missing.
