IP core for HD-SDI output.
I am looking for ip core to support HD-SDI output on Zynq ZC702 board. I found that LogiCORE ip triple-rate SDI can be used?.
Am I  right?, May I please know which hardware should be used since we don't have a on board Transmitter.
The Triple Rate SDI-IP is only available for spartan6 and virtex6.
For Zynq please refer below link for the SMPTE_SDI core which will support HD-SDI.
http://www.xilinx.com/products/intellectual-property/SMPTE_SDI.htm
Satish
Hallo satish,
Thanks. Do u know which transceiver is supported with this IP core and ZC702 board.
Have a look at the below XAPP for this core implementation on ZYNQ
http://www.xilinx.com/support/documentation/application_notes/xapp1092-smpte-sdi-zynq-gtx-transceivers.pdf
Satish
Hi Satish,
I went through it, but I guess the GTX transciever is not available on ZC702...The design is refrenced to Zynq ZC706...
Joshi
I overlooked that and you are correct the ZC702 part doesn't have any transciever.
You have to go for ZC706 if you need HD-SDI.
Satish
ZC702 do have a GTX transciever at LPC connectors J3 and J4 but, ZC702 doesn't have high speed  I/O ports !!!
Joshi
High speed serio IO and the transceivers are the same.
The device doesn't have any inbuilt transceievers and the connectors have signals as defined below
  • FMC #1-LPC connector (0 GTX Transceiver, 68 single-ended or 34 differential user defined signals)
  • FMC #2-LPC connector (0 GTX Transceiver, 68 single-ended or 34 differential user defined signals)
http://www.xilinx.com/products/boards-and-kits/EK-Z7-ZC702-G.htm
Also have a look at the below relevant post
http://forums.xilinx.com/t5/Embedded-Linux/External-hardware-for-HD-SDI-output-with-ZC702/td-p/358559
Satish
Yes you are right, the FMC connector from FMC 1(J3) or FMC 2(J4) to XC7Z020 AP SoC U1 doesn't have GTX. www.xilinx.com/support/documentation/boards_and_kits/zc702_zvik/ug850-zc702-eval-bd.pdf , pg. 51 explains!.
Thanks and regards,
Joshi
