IRQ Handler kernel level from PL
here I am again, with another silly question , I hope.
I want to generate an interruption from my PL, actually two,
so , they are physically connected to concat and goes to IRQ_F2P[4:0], they are ln3 and ln4.
I changed my devicetree , and they are showing up in the /proc/interrupts
57:         32          0       GIC  57  cdns-i2c
 61:          0          0       GIC  61  SII902x_det
 62:          0          0       GIC  62  xilinx-vdma-controller
 63:          0          0       GIC  63  0-0053
 64:          1          0       GIC  64  gpio1
 65:          2          0       GIC  65  gpio2
 72:          0          0       GIC  72  f8003000.dmac
then I kinda figure out two numbers for them in my kernel level IRQ SW ,
96 and 97 , then  I am able to register them with my module :
 73:          0          0       GIC  73  f8003000.dmac
 74:          0          0       GIC  74  f8003000.dmac
 75:          0          0       GIC  75  f8003000.dmac
 82:        814          0       GIC  82  xuartps
 96:          0          0  zynq-gpio   0  int-test
 97:          1          0  zynq-gpio   1  int-test2
146:          0          0  zynq-gpio  50  K1
IPI1:          0      52126  Timer broadcast interrupts
another tests show :
ls -l /proc/irq/97/
total 0
-r--r--r--    1 root     root             0 Jan  1 04:25 affinity_hint
dr-xr-xr-x    2 root     root             0 Jan  1 04:25 int-test2
-r--r--r--    1 root     root             0 Jan  1 04:25 node
-rw-r--r--    1 root     root             0 Jan  1 04:25 smp_affinity
-rw-r--r--    1 root     root             0 Jan  1 04:25 smp_affinity_list
-r--r--r--    1 root     root             0 Jan  1 04:25 spurious
which int-test2 is my handler at the kernel space.
BUT only IRQ happens and only ONCE , i see it in my serial cutecom console :
\0x1b[0;31mZ-turn#\0x1b[m random: nonblocking pool is initialized
\0x1b[0;31mZ-turn#\0x1b[m \0x1b[0;31mZ-turn#\0x1b[m \0x1b[0;31mZ-turn#\0x1b[m \0x1b[0;31mZ-turn#\0x1b[m \0x1b[0;31mZ-turn#\0x1b[m interrupt_hook!!
xilaxitimer_init: Registered IRQ 97
clcdint_init2
clcdint_init
you are able to see the IRQ counter incremented at the /proc/interrupts
97 BTW comes from a switch that I manually trigger , 96 is supposed to be a counter but it is not happening ,
the switch is happening at least once , but does not repeat.
maybe is my code , which is :
#include <linux/init.h>
#include <linux/module.h>
#include <linux/irq.h>
#include <linux/io.h>
#include <linux/irqdomain.h>
#include <linux/interrupt.h>
#include <linux/of.h>
#include <linux/of_address.h>
#include <asm/exception.h>
#include <asm/mach/irq.h>
#define INTERRUPT 97
MODULE_LICENSE("GPL");
static irqreturn_t interrupt_hook2(int irq, void *dev_id, struct pt_regs *regs) {
    printk("interrupt_hook!!\n");
    return IRQ_HANDLED;
static int __init clcdint_init2(void) {
    unsigned int irq;
    unsigned int irqflags;
    int ret;
    irq = INTERRUPT;
    irqflags = IRQF_NO_SUSPEND;
    ret = request_irq(irq, interrupt_hook2, irqflags, "int-test2", NULL);
    if(ret != 0) {
            printk("ERROR2: IRQ request failed %d", irq);
            printk(" - code %d , EIO %d , EINVAL %d\n", ret, EIO, EINVAL);
    else
        printk(KERN_INFO "xilaxitimer_init: Registered IRQ %d\n", irq);
    printk("clcdint_init2\n");
    return 0;
module_init(clcdint_init2);
static void __exit clcdint_exit2(void) {
    unsigned int irq;
    irq=INTERRUPT;
    free_irq(irq, NULL);
    printk("clcdint_exit\n");
module_exit(clcdint_exit2);
I am wondering if I need to clean the IRQ at the handler function,
and how to do it ?
Any other idea ?
Re: IRQ Handler kernel level from PL
I managed to make it work by re-compiling the KERNKEL with the option selected :
Device Drivers > Userspace I/O drivers > Userspace I/I platform with generic IRQ handling .
Then I use a code in the userspace to handle the IRQ via /dev/uio0 : the code is from :
link_to_devuio0handler
and finally the counter of the IRQ is counting at /proc/interrupts and the handler is being called.
I noticed that I am using the wrong interrupt number , and it is actually 32 and 33 for my two custom interrupts. Then the interrupts are registered under GIC :
32:          0          0       GIC  32  int-test
 33:          0          0       GIC  33  int-test2
but it is still not firing the IRQ handler , but then I used /dev/uio0 , to talk to the PL, and handle my IRQ from the PL.
The code that I used is based on:
https://yurovsky.github.io/2014/10/10/linux-uio-gpio-interrupt.html
