IRQ polling not possible with petalinux
it's me again :-)
Now i have reached a new dimension in debugging and testing my tiny app. My first Goal was to implement an user mode Interrupt handler on a petalinux image with uio.
Yes, i made some errors... but it is still not working!
It should be possible to make a blocking read with uio to trigger an incomming interrupt. But i'am not able to implement this. After that i tried to poll the IRQ-Status Register to fetch the Interrupt.
It is not working too! I can read and write data via uio into the gpio ip-core and i see the changing values if i read the gpio where the switches are connected to if i'am changing the switches.
So, when i'am able to read and write data from and to the gpio in Linux, why can't i get a changing irq Status, when i'am changing the Switches? (The hardware is independent from Linux, isn't it?)
FYI: The Bare Metal Version works.
Has anybody any suggestions?
regards, many thanks, and never ending happiness
deppenkaiser :-)
Re: IRQ polling not possible with petalinux
Your macro does not work.
