luluzhang
Import Vivado generated source code
I followed the steps in zynq book tutorial to generated bit file and c SDK project for the LED example.
when I try to import the SDK project, I don't how to import the project and what file should be added.
Thanks and Best Regards,
Ardeal
johnvivm
Voyager
Voyager
From the figure you already have an application project (LED_test), a Board Support Package (LED_test_bsp) and a Hardware Description File, that's all you need, no need to import anything else.
