rpjday
In PL 2019.1, what u-boot config option would cause build to *ignore* supplied platform-top.h?
With a current PL 2018.2 build, the recipe for u-boot-xlnx incorporates a lengthy platform-top.h file setting a bunch of software update variables for U-Boot. When the build is complete, I can check the generated u-boot.elf file and using "strings" and "grep", I can verify that those values are embedded in the u-boot.elf file.
I migrated that build structure to PL 2019.1 (trying to replicate everything, including configuration settings), but now, when i check u-boot.elf that is under build/tmp/deploy/images/..., *that* u-boot.elf file doesn't contain any of those strings; it's as if the build totally ignored the supplied platform-top.h file.
I set
RM_WORK_EXCLUDE += "u-boot-xlnx"
just to see what ends up in U-Boot's WORKDIR and, sure enough, platform-top.h is there, with all the correct content, but for some reason, the build doesn't pick up that content. Is there some 2019.1 configuration I've missed that directs U-Boot to incorporate the platform-top.h file in the final u-boot.elf?
rday
rpjday
OK, I think I see the problem, but not the cure. In the older (2018.2) project, if I look in WORKDIR/temp/, I see:
log.do_configure:Value of CONFIG_SYS_CONFIG_NAME is redefined by fragment /home/user/xilinx-petalinux/board/flint/project-spec/meta-plnx-generated/recipes-bsp/u-boot/configs/config.cfg:
log.do_configure:Previous value: CONFIG_SYS_CONFIG_NAME="<vendor>_<board>"
log.do_configure:New value: CONFIG_SYS_CONFIG_NAME="platform-top"
In short, something about the configuration of that project sees the original value of CONFIG_SYS_CONFIG_NAME as the vendor_board value (that's the value that is being explicitly set), but *something* comes along later and sets that to "platform-top", which is why "platform-top.h" is being included. But I don't see what causes that redefinition ... is there a top level setting that causes that?
And when I look at the 2019.1 project, that variable is *not* redefined, which explains why platform-top.h is not being included.
rday
shabbirk
Hi @rpjday
May I know how did you updated platform-top.h to add environment variables?
Can you check once u-boot.elf generated in images/linux/ ?
Best Regards
Shabbir
rpjday
The project's platform-top.h file was placed in the u-boot/files/ directory, and the bbappend file contains the line:
SRC_URI += "file://platform-top.h"
And as I mentioned, I verified that that project-specific platform-top.h file does end up being copied into u-boot-xlnx's WORKDIR, way down under tmp/work/.../u-boot-xlnx/... (along with platform-auto.h, which is #included from platform-top.h).
The u-boot.elf under images/linux/ is similarly missing any of the content from platform-top.h.
Has anything changed regarding the processing of platform-top.h from 2018.2 to 2019.1? Am I overlooking some new configuration that needs to be set?
rday
rday
rpjday
Just to be clear, I inherited the original 2018.2 PL project and, as I read it, to add extra env info to U-Boot, one needed only to add a platform-top.h file to files/, then add a reference to that file in SRC_URI in the u-boot-xlnx bbappend file, at which point normal U-Boot processing would *automatically* include it as part of the build. Is there some additional switch or config that needs to be thrown for that to happen?
I've certainly verified that that platform-top.h file ends up in u-boot's WORKDIR directory, so I'm just speculating that, even though it's there, it is for some reason being ignored. That's not what happened in the 2018.2 project.
rday
rpjday
rday
jrhtech
If autoconfigure is not enabled for u-boot it will not include platform-top.h.   I figured this out when going from a 2019.2 to 2020.1 and my u-boot didn't build because platform-top.h was not being imported to the bit tree.
In 2019.1 there was a rule somewhere, that would copy platform-top and platform-auto into the source tree when building; however, in 2020.1 one this wasn't happening.  But then looking at a zcu102 BSP I saw this in the u-boot bbappend in meta-user.
do_configure_append () {
if [ "${U_BOOT_AUTO_CONFIG}" = "1" ]; then
install ${WORKDIR}/platform-auto.h ${S}/include/configs/
install ${WORKDIR}/platform-top.h ${S}/include/configs/
fi
Note that auto_config has to be enabled for this to work.  I'm pretty sure 2019 is doing this same check somewhere(but I couldn't find it) to take care of the copy you were looking for.
jeff
