Include i2cdetect in PetaLinux
It seems as though I do not have i2cdetect Linux tool included in PetaLinux. I am trying to write a basic I2C Linux application which is failing to write bytes to I2C. Since I am running it within QEMU, it is fairly difficult to debug without this tool. How do you include i2cdetect in PetaLinux?
root@plnx_arm:~# i2cdetect -r -y 0
-sh: i2cdetect: command not found
Tags (2)
Re: Include i2cdetect in PetaLinux
Hi @jackfrye11 ,
There is a way to enable i2cdetect, i2cget e.t.c. commands in Petalinux without any installation.
You need to run "petalinux-config -c rootfs" command, then find i2ctools and enable it, build new image and you got it.
Not: I read your messaging but Solution misrouted me, that's why I m answering tour question.
Saban
Voyager
Voyager
Hey @jackfrye11,
You want to add the i2c-tools package for i2cdetect.
Hope this helps,
Herbert
-------------- Yes, I do this for fun!
@hpoetzl, is there a way to install apt-get or similar packaging utilities? I have installed i2cdetect before. Is it possible to install it manually, since I am in a secured environment?
Voyager
Voyager
Hey @jackfrye11,
There is no package manager in petalinux, you need to add the package via a build recipe so that it can be 'built' into your image.
Note that if you prefer a pacakge based distro like Debian, Ubuntu, Arch, etc. you can simply forget about petalinux and use your favorite ARM based distro instead (that's why I do most of the time).
Best,
Herbert
Hi @jackfrye11 ,
Saban
