Visitor varunmurali1
Incosistent power on results with ZCU104
We purchased a ZCU104 evaluation board recently and get this error periodically while using the board. The SD card is loaded with a base PYNQ image.
[ 6.595100] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 6.603720] cfg80211: failed to load regulatory.db
[ 7.019070] [drm] Cannot find any crtc or sizes
[ 17.911037] mmc0: Timeout waiting for hardware cmd interrupt.
[ 17.916784] mmc0: sdhci: ============ SDHCI REGISTER DUMP ===========
[ 17.923219] mmc0: sdhci: Sys addr: 0x00000008 | Version: 0x00001002
[ 17.929650] mmc0: sdhci: Blk size: 0x00007200 | Blk cnt: 0x00000000
[ 17.936082] mmc0: sdhci: Argument: 0xaaaa0000 | Trn mode: 0x00000023
[ 17.942514] mmc0: sdhci: Present: 0x01f70000 | Host ctl: 0x0000001f
[ 17.948946] mmc0: sdhci: Power: 0x0000000f | Blk gap: 0x00000080
[ 17.955378] mmc0: sdhci: Wake-up: 0x00000000 | Clock: 0x00000207
[ 17.961809] mmc0: sdhci: Timeout: 0x00000009 | Int stat: 0x00000001
[ 17.968242] mmc0: sdhci: Int enab: 0x02ff008b | Sig enab: 0x02ff008b
[ 17.974673] mmc0: sdhci: AC12 err: 0x00000000 | Slot int: 0x00000001
[ 17.981105] mmc0: sdhci: Caps: 0x31e8c881 | Caps_1: 0x00002007
[ 17.987537] mmc0: sdhci: Cmd: 0x00000d1a | Max curr: 0x00000000
[ 17.993969] mmc0: sdhci: Resp[0]: 0x00000900 | Resp[1]: 0x0076b27f
[ 18.000401] mmc0: sdhci: Resp[2]: 0x325b5900 | Resp[3]: 0x00000900
[ 18.006832] mmc0: sdhci: Host ctl2: 0x00000000
[ 18.011268] mmc0: sdhci: ADMA Err: 0x00000000 | ADMA Ptr: 0x000000005fc9820c
Teacher drjohnsmith
Re: Incosistent power on results with ZCU104
easiest guess is you have a SD card thats not up to the job,
This error is now repeatable using 2 new SD cards (San Disk 16Gb).
Teacher drjohnsmith
Apart form trying a faster card, or from different manufacturers,
Im out of guesses then,
Hello @varunmurali1 ,
Please check the following similar forum topic and see if this helps?
https://forums.xilinx.com/t5/Embedded-Linux/zcu102-petalinux-booting-error/td-p/995034
Hope this helps.
Kind Regards,
Anatoli Curran,
Xilinx Technical Support
Hello @varunmurali1
Please refer following Answer record for finding work around on this issue:
https://www.xilinx.com/support/answers/73079.html
You will need to add following DT node and rebuild your images.
# system-user.dtsi content
"/include/ "system-conf.dtsi"
&sdhci1 {
        no-1-8-v;
