bell_a
Installation error PetaLinux "Exec format error"
I want to install PetaLinux 2019.1 on Ubuntu 18.04.5 LTS 64-bit. When installing, I see:
"petalinux-v2019.1-final-installer.run: cannot execute binary file: Exec format error".
How can I solve this problem?
rodrirq
That's quite strange. I get that kind of error when I try to run on Ubuntu something that I cross-compiled for ARM.
Are you working with Linux on a virtual machine?
rodrirq
That kind of error happens when you try to install PetaLinux on a 32-bit OS, but you said that it is 18.04.5 LTS 64-bit.
Do you need 2019.1 for a specific reason? If not try to upgrade to 2020.2.
bell_a
Hello, no, ubuntu is base OS.
watari
Professor
Professor
Hi @bell_a
Would you try the following ?
bash petalinux-v2019.1-final-installer.run
Hope this helps.
Best regards,
aravindb
HI @bell_a
Looks you are running 64 bit installer on 32-bit machine.
Can you please check your machine Arch 32 bit or 64 bit.
Note: You cannot install the tool as root user.
Thanks & regards
Aravind
