Installation of Petalinux SDK on Ubuntu 12.04 LTS
Hello ,
   I have installed 14.7 Version of ISE and installed Petalinux v2013 Final on Ubuntu 12.04 LTS. I have installed necessary dependancy tools listed in petalinux installation guide..
The license manager also detected the license and Host ID Matches and Licence crc says "OKAY".
I also installed the SDK Plugin for xsdk.
Whenever i launch xsdk after installation, it displays as below
SDK Environment = /home/xxxxx/bin/petalinux/petalinux-v2013.10-final
PetaLinux License is not valid or not installed.
plat[dirt] - Platform Configuration Marked Dirty
Let me know what could be the issue
Re: Installation of Petalinux SDK on Ubuntu 12.04 LTS
I dont think petalinux 2013.10 has a SDK plugin as we had earlier. Refer to this post.
http://forums.xilinx.com/t5/Embedded-Linux/PetaLinux-2013-10-SDK-Integration/td-p/387119
--Hem
I have attached the xinfo file for the reference
The Petalinux Plugin i'm using is PetaLinux SDK 1.0.0.2--cLp1vE773593A5I53CE
file:/home/nrossi/plgx/src/eclipse-plugin/output/com.petalogix.sdk.site/target/site/site.xml.petalinuxsdk
--Hem
Hello htsvn,
   Thanks for the reply.  Now i got the things working.
I installed petalinux sdk refrring Ug977 pdf , petalinux2012.12 on ubuntu 12.04 .sdk 14.4.. and also petalinux plugin referring Ug979 pdf.for the first time i was getting petalinux sdk menu. when i open for the second time i am not getting petalinux sdk menu..on the console
i get this information like
SDK Environment = /opt/petalinux-v12.12-final-full
anybody help to resolve it..
Visitor l6j6p6
same here
so did you solve it?
