Milind
Installing Ubuntu Linux deb packages on Zcu102 sdcard boot image
I would like to install Ubuntu packages such as gcc, nettools etc on Zcu102 board. I have built kernel using petalinux and made sd card bootable with image and also configured board Ethernet port to access internet. I could boot from SD card and access internet.
However the existing OS on the board Sd card has limited commands, utilities and packages, I would like to install few more and also install GNU C compiler. normally this is done using dpkg or apt-get command. But these packages are also not installed by default.
Could any one help me with the procedure to get apt and dpkg activated / installed,
thanks in advance.
mIlind.
