badFITimage
Instantiation of EMIO GPIO as interrupt in device tree
Hi I have a specific SPI device that we have instantiated with the device tree node in which the driver of the device requires an interrupt from a peripherial device. We've routed an EMIO pin but unsure how we go about instantiating this within our device. Can anyone provide an example of a GPIO configured as an interrupt for a serial communication device tree node? Thanks in advance!
aravindb
HI @badFITimage
Please follow below link for configuring gpio as irq:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842398/Linux+GPIO+Driver
Thanks & regards
Aravind
aravindb
HI @badFITimage
Thanks & regards
Aravind
