Intermittent hang in Linux boot after "Freeing unused kernel memory" on Zynq 7015
I have boot up problem, I use Petalinux 2014.4 and 95% of the time the boot works just fine. However sometimes it hangs just after the freeing unused kernel memory message. That message is always fine but the next line is always corrupt. Any ideas as to how to debug and fix?
Here is a hang
U-Boot 2014.07 (Feb 03 2017 - 14:53:42)
DRAM: ECC disabled 1 GiB
MMC: zynq_sdhci: 0
SF: Detected S25FL512S_256K with page size 512 Bytes, erase size 256 KiB, total 64 MiB
In: serial
Out: serial
Err: serial
Net: Gem.e000b000
Warning: failed to set MAC address
U-BOOT for Enclustra
Device: zynq_sdhci
Manufacturer ID: 74
OEM: 4a60
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 4-bit
reading image.ub
8123624 bytes read in 687 ms (11.3 MiB/s)
## Loading kernel from FIT Image at 01000000 ...
Using 'conf@1' configuration
Trying 'kernel@1' kernel subimage
Description: PetaLinux Kernel
Type: Kernel Image
Compression: gzip compressed
Data Start: 0x010000f0
Data Size: 8105168 Bytes = 7.7 MiB
Architecture: ARM
OS: Linux
Load Address: 0x00008000
Entry Point: 0x00008000
Hash algo: crc32
Hash value: 62b1f187
Verifying Hash Integrity ... crc32+ OK
## Loading fdt from FIT Image at 01000000 ...
Trying 'fdt@1' fdt subimage
Description: Flattened Device Tree blob
Type: Flat Device Tree
Compression: uncompressed
Data Start: 0x017baea4
Data Size: 17158 Bytes = 16.8 KiB
Architecture: ARM
Hash algo: crc32
Hash value: 93c0bf7f
Booting using the fdt blob at 0x17baea4
Uncompressing Kernel Image ... OK
Loading Device Tree to 07ff8000, end 07fff305 ... OK
Starting kernel ...
Linux version 3.17.0-xilinx (david@ubuntu) (gcc version 4.8.3 20140320 (prerelease) (Sourcery CodeBench Lite 2014.05-23) ) #29 SMP PREEMPT Thu May 18 13:31:09 BST 2017
Machine model: Lu250
cma: Reserved 128 MiB at 38000000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @7779b000 s8704 r8192 d15872 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 260096
Kernel command line: console=ttyPS0,115200 earlyprintk
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 896620K/1048576K available (4594K kernel code, 239K rwdata, 1580K rodata, 4840K init, 198K bss, 151956K reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
vmalloc : 0x80800000 - 0xff000000 (2024 MB)
lowmem : 0x40000000 - 0x80000000 (1024 MB)
pkmap : 0x3fe00000 - 0x40000000 ( 2 MB)
modules : 0x3f000000 - 0x3fe00000 ( 14 MB)
.text : 0x40008000 - 0x4060fd14 (6176 kB)
.init : 0x40610000 - 0x40aca200 (4841 kB)
.data : 0x40acc000 - 0x40b07c60 ( 240 kB)
.bss : 0x40b07c60 - 0x40b3948c ( 199 kB)
Dump stacks of tasks blocking RCU-preempt GP.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
L2C: platform provided aux values match the hardware, so have no effect. Please remove them.
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76360001
slcr mapped to 80804000
zynq_clock_init: clkc starts at 80804100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 3298534883328ns
timer #0 at 80806000, irq=43
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Setting up static identity map for 0x457348 - 0x4573a0
CPU1: Booted secondary processor
Brought up 2 CPUs
SMP: Total of 2 processors activated.
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
regulator-dummy: no parameters
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0x80880000
GPIO IRQ not connected
XGpio: /amba_pl/gpio@41200000: registered, base is 130
VCCPINT: 1000 mV
vgaarb: loaded
SCSI subsystem initialized
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
Switched to clocksource arm_global_timer
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
TCP: reno registered
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
msgmni has been set to 2007
io scheduler noop registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-2364208
dma-pl330 f8003000.dmac: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0000000.serial: ttyPS0 at MMIO 0xe0000000 (irq = 59, base_baud = 6249999) is a xuartps
console [ttyPS0] enabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to 8081a000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
m25p80 spi32766.0: found s25fl512s, expected n25q128a11
m25p80 spi32766.0: s25fl512s (65536 Kbytes)
5 ofpart partitions found on MTD device spi32766.0
Creating 5 MTD partitions on "spi32766.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000540000 : "bootenv"
0x000000540000-0x000000fc0000 : "kernel"
0x000000fc0000-0x000001000000 : "serial_no"
0x000001000000-0x000004000000 : "spare"
e1000e: Intel(R) PRO/1000 Network Driver - 2.3.2-k
e1000e: Copyright(c) 1999 - 2014 Intel Corporation.
libphy: XEMACPS mii bus: probed
xemacps e000b000.ethernet: pdev->id -1, baseaddr 0xe000b000, irq 54
ehci-pci: EHCI PCI platform driver
ULPI transceiver vendor/product ID 0x0424/0x0007
Found SMSC USB3320 ULPI transceiver.
ULPI integrity check: passed.
zynq-ehci zynq-ehci.0: Xilinx Zynq USB EHCI Host Controller
zynq-ehci zynq-ehci.0: new USB bus registered, assigned bus number 1
zynq-ehci zynq-ehci.0: irq 53, io mem 0x00000000
zynq-ehci zynq-ehci.0: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
cdns-i2c e0004000.i2c: 400 kHz mmio e0004000 irq 57
cdns-wdt f8005000.watchdog: Xilinx Watchdog Timer at 808c6000 with timeout 10s
zynq-edac f8006000.memory-controller: ecc not enabled
Xilinx Zynq CpuIdle Driver started
sdhci-arasan e0100000.sdhci: No vmmc regulator found
sdhci-arasan e0100000.sdhci: No vqmmc regulator found
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbhid: USB HID core driver
TCP: cubic registered
/media/disk3/petalinux-v2014.4-final/components/linux-kernel/xlnx-3.17/drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
ALSA device list:
No soundcards found.
Freeing unused kernel memory: 4840K (40610000 - 40aca000)
­,L'H«ö­Z-¤.\YY²SDHC card at address b368
And the normal complete boot
MMC: zynq_sdhci: 0
In: serial
Out: serial
Err: serial
Net: Gem.e000b000
Device: zynq_sdhci
Manufacturer ID: 74
OEM: 4a60
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 3.7 GiB
Bus Width: 4-bit
reading image.ub
Type: Kernel Image
Architecture: ARM
OS: Linux
Hash algo: crc32
Architecture: ARM
Hash algo: crc32
Starting kernel ...
Zynq clock init
Brought up 2 CPUs
VCCPINT: 1000 mV
vgaarb: loaded
EDAC MC: Ver: 3.0.0
brd: module loaded
loop: module loaded
ALSA device list:
mmc0: new high speed SDHC card at address b368
mmcblk0: mmc0:b368 USD 3.71 GiB
mmcblk0: p1
INIT: version 2.88 booting
Creating /dev/flash/* device nodes
random: dd urandom read with 8 bits of entropy available
starting Busybox inet Daemon: inetd... done.
update-rc.d: /etc/init.d/run-postinsts exists during rc.d purge (continuing)
Removing any system startup links for run-postinsts ...
/etc/rcS.d/S99run-postinsts
INIT: Entering runlevel: 5
Configuring network interfaces... done.
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQC8e/aNrX57VGvg5gpXqtG2cNfSDrURsYILeelr+woK8JdWxANZ1ECKeJUui8eS53aI6yMXw2nFeO4qlCfk0+pCUJhE+13Bi7bqxBXa5ADN03bU4FjkQxxgYgFcMTL/OJMGOSdhlq/A0F8Ei+yAQS3GuMQOey+6V5dRrarT6Rza8Y/7ilYh6sC/cb5TQl0sNrsDYUGYfR7ViQGemr8T5YXaK4SEn3hv7S0megQ+xAAeBTQGteVdXSoqiy+n8wm3El9SaRr69ySEBFAQ8lDxaQMyTXkiM8lxPKOVrRioBmRmDOGVzQ13wzHgT0g84Z1OaWpKirjbXysJ5Q/CR3LNZTHR root@Enclustra
Fingerprint: md5 41:a6:d3:50:e8:9f:5c:10:33:cf:24:b5:d8:ec:9b:25
NET: Registered protocol family 10
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
dropbear.
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
no test LVDS
startup
random: nonblocking pool is initialized
luscher 40400000.luscher: Device Tree Probing
luscher 40400000.luscher: luscher at 0x40400000 mapped to 0x80980000, irq=91
buff size 0x00040000
buff number 0x00000080
DMA buffer at 38100000 size 33562624
SG table at 3a100000
open
version 117
major 1 minor 3
ioctl - reset
Starting tcf-agent: OK
Built with PetaLinux v2014.4 (Yocto 1.7) Enclustra /dev/ttyPS0
Enclustra login:
I don't think it is power supply, the fail is always at the same point several seconds after power up.
Thanks for looking
Dave
I have taken out the SD card device from the boot by disabling it in the device tree. No hang up so it is SD card related.
