Interrupt enable for DpRx
HW: zynq zcu102 MPSoc, Design DpRx example design.
I haver ported the SDK standalone code in linux environment.
I want to enable the enterrupt in the local host environment and work with Interrupt handlers.
How do I do that?
Best Regards,
Akanksha Singh
Tags (2)
Re: Interrupt enable for DpRx
Hi @chrisar,
Any inputs to this customer?
Sandeep
