Interrupt handling with UIO
hello, I'm trying to port a baremetal design, in which I have a simple HLS IP that performs vector additions, that triggers an interrupt when it finishes its computation.
This is my Vivado block design:
Then after the bitstream generation I exported the hdf and I generated the Petalinux project based on it, in which I specified "generic-uio" in the compatible field as follows:
amba_pl: amba_pl {
		#address-cells = <1>;
		#size-cells = <1>;
		compatible = "simple-bus";
		ranges ;
		&irq_gen_0: irq_gen@43c00000 {
			clock-names = "ap_clk";
			clocks = <&clkc 15>;
			compatible = "generic-uio";
			interrupt-names = "interrupt";
			interrupt-parent = <&intc>;
			interrupts = <0 29 4>;
			reg = <0x43c00000 0x10000>;
			xlnx,s-axi-axilites-addr-width = <0xb>;
			xlnx,s-axi-axilites-data-width = <0x20>;
After booting Linux on my Zedboard, I can see the uio device, and the interrupt:
then I created a simple application that starts my IP, using the UIO drivers generated through Vivado HLS:
int a[N];
	int b[N];
	for(int i = 0; i < N; ++i) {
		a[i] = i;
		b[i] = i;
	XIrq_gen HLSdevice;
	XIrq_gen_Initialize(&HLSdevice, "irq_gen");
	XIrq_gen_Write_a_Words(&HLSdevice, 0, a, N);
	XIrq_gen_Write_b_Words(&HLSdevice, 0, b, N);
	XIrq_gen_Start(&HLSdevice);
	while(!XIrq_gen_IsDone(&HLSdevice));
	XIrq_gen_Release(&HLSdevice);
Finally after this program finish its execution if I check /proc/interrupts, I don't see any interrupt generated by the HLP IP, I don't think that is a design issue, because the same example works on baremetal.
Could anyone help? thanks
