Visitor rfalise
Interrupt problem
I am trying to produce an interrupt on a custom board running Linux 2.6.29.  I am using the following generic counter...
INTR_PROC : process( Bus2IP_Clk ) is
    constant COUNT_SIZE   : integer := 30;
    constant ALL_ONES     : std_logic_vector(0 to COUNT_SIZE-1) := (others => '1');
    variable counter      : std_logic_vector(0 to COUNT_SIZE-1);
  begin
    if ( Bus2IP_Clk'event and Bus2IP_Clk = '1' ) then
      if ( Bus2IP_Reset = '1' ) then
        counter := (others => '0');
        interrupt <= (others => '0');
      else
        counter := counter + 1;
        if ( counter = ALL_ONES ) then
          interrupt <= (others => '1');
          else
        end if;
      end if;
    end if;
  end process INTR_PROC;
  IP2Bus_IntrEvent <= interrupt;
When I look at /proc/interrupts, I never see a change on my custom peripheral.   Am I missing something in the above code?
Thanks in advance,
~Ron
Re: Interrupt problem
There's a lot of details missing there, and not exactly the right crowd for reviewing hdl possibly.
I have not tried what you're doing, so not an expert here.
I'm not sure if proc interrupts will show anything as you may need device tree entries for a device connected to the interrupt.  To my knowledge, proc/interrupts only shows the devices that drivers have been found for.
Is the interrupt connected to the interrupt controller?
-- John
Visitor rfalise
The interrupt is connected to the interrupt controller.
 # cat /proc/interrupts
           CPU0
 16:       1204  Xilinx INTC Edge      serial
 19:          0  Xilinx INTC Edge      digital-drop-receiver-0
My peripheral is the digital-drop-receiver.  I was under the impression that when an interrupt occurs, the values above would reflect that.
My peripheral has an IRQ=9 (from the DTS file) and this corresponds to IER= 0x00000280.  So, I believe I have enabled the interrupt properly?
I understand this may not be the place to ask questions regarding VHDL.  The code was generated by the Peripheral Wizard (hopefully it is correct) and I was hoping to get a verification as to its correctness.  Any other info I can provide?
~Ron
Everything you said makes sense.  Interesting... haven't used that part of the EDK.
Do you have a device driver that got installed for the device?
I'm not sure if you have to connect the interrupt handler to get all that to work or not?  Until a handler is connected it may consider it a spurious interrupt and then not count it, not sure?
I'd create a simple device driver and if I didn't see interrupts, I'd probably put a chipscope in to verify the interrupt is toggling or I'd put it out to a GPIO pin and put a scope on it.
Sorry I'm not more help here.
-- John
Anonymous
Not applicable
A few questions:
Have you verified that this HDL works in simulation? In hardware?
Have you tested this out with a driver in a non-Linux system (i.e. using standalone BSP) to make sure you get interrupts?
Terry
Visitor rfalise
Sorry it took so long to get back to this...got pulled in a different direction for a while.
I did verify that this works in simulation.  Using Chipscope I never see a change in the interrupt line, and I have a standalone BSP to monitor the interrupt line and again, no change.
~Ron
