Visitor tomams
Interrupts, GPIO & External
I try to use GPIO & external interrupts. I do not see in the cat /proc/interrupts. I do see the interrupts in dts file for GPIO but not for external interrupt
Please can you let me know how to get them?
tom
Re: Interrupts, GPIO & External
Make sure the driver is compiled into the kernel.
In the kernel menu config, set
Device Drivers ->  GPIO Support -> Xilinx GPIO support
-Brian
The GPIO driver does not support interrupts at this time so you wouldn't see them in proc/interrupts.
The device tree file would have them if you put them into the EDK system as it's a reflection of the EDK system (system.mhs).
Visitor tomams
Thanks. What about the external interrupt signal directly connected to the interrupt controller. How do I access/see on the linux.?
You would need to hook into the interrrupt system like done in drivers.
You might be able to do some kind of user mode driver as I think they can use interrupts.   I don't know much about what kind of performance to expect there,  but I would expect it to be slow.
What's your application so that we better understand your requirements for the future?
Tom,
Whether or not a device uses interrupts is essentially opaque to the user application that uses the driver. For example,
a read on the device could either return the most recently read value which was read by the driver at the last interrupt, or, it could just go and read from the device on the spot.  A select could poll in user space for a change in value, or poll in the kernel for a change in value, or put the process to sleep until the next device interrupt.  The ways to implement the driver are very numerous (off the top of my head, I don't know what choices this particular driver did make. The application could be written the same regardless of whether the driver uses interrupts or not.
To re-architect the driver to use interrupts rather than polling won't be a 10 minue job, so I'd really only seriously consider it if you are planning on using GPIO as some sort of input data bus and have some throughput needs to achieve.
You can read up on some of this drivers usage details here:
http://xilinx.wikidot.com/osl-gpio-driver
-Brian
Visitor tomams
Thanks for your responses. This is actually the continuation of the touch screen issue. I need to use interrupt for pen_irq. I can use it thro GPIO or directly connect to the interrupt contoller.
I have been using stand alone system for long time. Now, I am switching all my systems to linux based. I have many devices(pcores) which use interrupt.
tom
