e.friel
Is fsbl.elf universal for different hardware descriptions?
The fsbl is used for configuring the zynq processing system at boot and then the bitstream is used to configure the PL fabric. I want to know if the fsbl is specific to each hardware description file i.e generate a different fsbl.elf for different hdf's or can I use the one fsbl.elf to configure the PS for multiple hardware descriptions?
sandeepg
Hi @e.friel ,
It is always recommend to build fsbl with different hdf.
Sandeep
sandeepg
Hi @e.friel ,
Sandeep
