lokesh_oepl
Is is possible to update configurations after creating project with BSP ?
Hello There,
I'm working with Petalinux to get Ethernet and USB Host working.
I have a Xilinx.BSP for our custom board and with that BSP if I create Petalinux Project, it works perfectly fine with Ethernet and USB settings. If I create a project  with zynq tempate, with new .hdf file, then I'm not able to get Ethernet and USb working, even if I use the system-user.dtsi with required changes.
Now, I want to do following things -
  1. petalinux-create --type project --source xilinx.bsp --name Test1
  2. cd Test1
  3. petalinux-config --get-hw-description=/home/work/Project1/settings.hdf
Will this update the PL settings and keep Ethernet and USB related settings as it is.???
I'm using MYIR's Z-turn Board, Petalinux 2019.2.
Looking forward to get quick and positive response,
Lokesh
Lokesh J.
aravindb
HI @lokesh_oepl
If we build the design with template option, somehow the USB  host mode is not working in Linux . But from u-boot , it is working fine.
Please change the  MACHINE_NAME as zc702 in DTG settings & build like below ,It should work in u-boot & linux.
For your reference:
petalinux-config
DTG Settings  --->(zc702) MACHINE_NAME
Thanks & regards
Aravind
aravindb
HI @lokesh_oepl
For your reference:
petalinux-config
Thanks & regards
Aravind
