Visitor vicentiu
Is it possible to have multiple Petalinux versions installed on the same system?
Is there a way to install multiple versions of Petalinux in different folders and activate the needed version by sourcing the settings.sh from their respective installs?
I tried installing a second version, but I got bitbake errors in that second version which went away when it was the only version installed.
thanks
Vicentiu
Re: Is it possible to have multiple Petalinux versions installed on the same system?
Hi @vicentiu
There should be no conflict as long as they are installed in separate directories and you need  to source settings.sh from only one version per terminal session.
Thanks & regards
Aravind
Hi @vicentiu
Thanks & regards
Aravind
Visitor vicentiu
Thanks. I'll post again if I run into any issues.
