Observer zosvitta
Issue with upgrading to petalinux 2018.3
I am trying to upgrade my codebase running on petalinux 2017.2 to latest 2018.3.
My code base involves displayport application.
I have generated the .sysdef and .bit files using 2018.3 vivado sdk and used in petalinux build.
My /project-spec/meta-user/recipes-bsp/device-tree/files/system-user.dtsi contains entries corresponding to displayport as shown below,
&xilinx_drm {
    status = "okay";
    clocks = <&idt5901>;
    xlnx,vid-clk-pl;
    planes {
        xlnx,pixel-format = "argb8888";
&xlnx_dp {
    status = "okay";
    phy-names = "dp-phy0", "dp-phy1";
    phys = <&lane3 PHY_TYPE_DP 0 3 27000000>, <&lane2 PHY_TYPE_DP 1 3 27000000>;
&xlnx_dp_sub {
    status = "okay";
    xlnx,vid-clk-pl;
    xlnx,gfx-fmt = "argb8888";
&xlnx_dp_snd_card {
    status = "okay";
&xlnx_dp_snd_codec0 {
    status = "okay";
&xlnx_dp_snd_pcm0 {
    status = "okay";
&xlnx_dp_snd_pcm1 {
    status = "okay";
But during the build, I get errors as
| Error: /build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/system-user.dtsi:156.1-12 Label or path xilinx_drm not found
| Error: /build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/system-user.dtsi:165.1-9 Label or path xlnx_dp not found
| Error: /build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/system-user.dtsi:171.1-13 Label or path xlnx_dp_sub not found
| Error: /build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/system-user.dtsi:177.1-18 Label or path xlnx_dp_snd_card not found
| Error: /build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/system-user.dtsi:181.1-20 Label or path xlnx_dp_snd_codec0 not found
| Error: /build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/system-user.dtsi:185.1-18 Label or path xlnx_dp_snd_pcm0 not found
| Error: /build/tmp/work/plnx_zynqmp-xilinx-linux/device-tree/xilinx+gitAUTOINC+b7466bbeee-r0/system-user.dtsi:189.1-18 Label or path xlnx_dp_snd_pcm1 not found
Could you please help me with the reason behind this issue and how can I fix it?
Thanks alot in advance.
Re: Issue with upgrading to petalinux 2018.3
Make sure that the labels that you are referencing in your dtsi (for example xilinx_drm) exist in the auto generated dts and dtsi files.
They should be located here:
<plnx-proj-root>/components/plnx_workspace/device-tree/device-tree/
The label names could be different or not created.
Christophe
Observer zosvitta
Thankyou for your reply.
I have modified the dtsi file as below.
&xilinx_drm {
    status = "okay";
    xlnx,vid-clk-pl;
    planes {
&xlnx_dp {
    status = "okay";
&xlnx_dp_sub {
    status = "okay";
    xlnx,vid-clk-pl;
&xlnx_dp_snd_card {
    status = "okay";
    status = "okay";
&xlnx_dp_snd_pcm0 {
    status = "okay";
&xlnx_dp_snd_pcm1 {
    status = "okay";
&zynqmp_dpsub {
    status = "okay";
&xlnx_dpdma {
    status = "okay";
Since in the new 4.14 kernal from xilinx the displayport device tree has been modified (Reference: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842105/ZynqMP+DisplayPort+Linux+driver)
Build passes. But my uboot does not recognize the kernal image.
Wrong Image Format for bootm command
ERROR: can't get kernel image!
ZynqMP>
I notice that my image.ub is 27.5MB,  where as Image is 79.6MB, system.dtb is 35kB and rootfs.jffs2 is 27.5MB.
So I think that kernel image (Image) is not included in image.ub.
Is it causing the problem with uboot?
How can I fix it?
Thanks a lot.
