Observer twong168
JTAGTERMINAL with xczu11eg component
Hi:
   I am working on a custom board with the xczu11eg component.  It does not yet have a real UART.
I have tried to run u-boot using the JTAG interface.  I could see from the JTAG output that the pmufw.elf, zynqmp_fsbl.elf, bl31.elf and u-boot.elf images are all loaded.  I was hoping I could use jtagterminal to see u-boot booting messages.  But I only saw the hyperterminal popping up.  Besides the header, there were no other messages.  I have recompiled the u-boot.elf from source after enabling CONFIG_DEBUG_UART_ARM_DCC.  Is this enough to redirect STDIN/STDOUT to jtagterminal?  The only information I could find online does not seem to apply to UltraScale+ MPSoC.  I am including my XSDB script below.  Perhaps someone can point out what I need to do in order to make jtagterminal work?
Thanks in advance.
TW
connect
# Reset the processors
targets -set -nocase -filter {name =~ "*APU*"}
stop
rst -system
exec sleep 2
targets -set -nocase -filter {name =~ "*PMU*"}
stop
rst -system
exec sleep 2
# Set up PS Unit
targets -set -nocase -filter {name =~ "*PSU*"}
stop
rst -system
exec sleep 2
# Disable jtag_sec
mwr 0xFFCA0038 0x1ff
# Load Platform Manager
targets -set -nocase -filter {name =~ "*MicroBlaze PMU*"}
dow "pmufw.elf"
exec sleep 2
# start PMU
con
exec sleep 2
# Set up APU
# Write to configure start of 3rd OCM memory bank
mwr 0xFFFF0000 0x14000000
# Reset FPD_APU
mwr 0xFD1A0104 0x501
exec sleep 2
mwr 0xFD1A0104 0x0
exec sleep 2
# Load and start FSBL
targets -set -nocase -filter {name =~ "*A53*#0"}
dow "zynqmp_fsbl.elf"
exec sleep 2
con
exec sleep 2
# Write bootloop and release A53-0 reset
mwr 0xFFFF0000 0x14000000;
Bring A53_0 out of reset
mwr 0xFD1A0104 0x380E;
exec sleep 2
source psu_init.tcl;
psu_init;
psu_post_config;
# MIO PINS
mwr -force 0xFF1800A8 0xC0;
mwr -force 0xFF1800AC 0xC0;
exec sleep 2
# Load U-Boot and bl31 images
dow "u-boot-dcc.elf"
exec sleep 2
dow "bl31.elf"
exec sleep 2
# Load Linux image to memory
dow -data "image.ub" 0x1000000
exec sleep 2
# Use JTAG UART
jtagterminal
# Start A53 processor
con
