Observer ralphkw1
Just getting started with Petalinux 2017.2, need more documentation for shared library compiling, installation
I have created apps, but now I need to create a shared library that also copies API header files to sysroot for use by all of my applications. I have not been able to find any documentation references nor have I been able to find any tutorials. Can someone provide any links or examples for a shared library recipe.
Ralph
Scholar hbucher
Re: Just getting started with Petalinux 2017.2, need more documentation for shared library compiling, installation
@ralphkw1
Check out this wiki link:
http://www.wiki.xilinx.com/Build+Kernel
More specifically to your case,  see step 3 here
http://www.wiki.xilinx.com/Build+and+Modify+a+Rootfs
If you are asking about how to build a shared library in linux in general, here is a good tutorial
http://www.cprogramming.com/tutorial/shared-libraries-linux-gcc.html
If you want to cross compile for the ARM
http://xilinx.wikidot.com/zynq-app-debug
The ARM cross compiler is included in your Vivado install at
D:\xilinx\Windows\SDK\2017.2\gnu\aarch32\nt\gcc-arm-none-eabi\bin
Hope this helps
Observer ralphkw1
Thanks for the response, but none of these are examples of petalinux/yocto recipes for shared library, which is what I need. I already have the apps and shared libraries working in petalinux 15.4. Just need to figure out how to compile/install them in PL17.2 which appears to be a totally different animal.
BR,
Ralph
Observer ralphkw1
Really nobody has a shared library recipe? Even Xilinx folks?
Scholar hbucher
@ralphkw1
Well this by no means is specific to petalinux or yocto. Unless I did not understand your question
which library is it? have you checked if already exists a recipe in the yocto git repository?
I have added library to my build in 2 different ways:  1)cloning an existing recipe in my yocto source directory; 2)cross-compling a library through petalinux.
let me explain it with examples,
1)Installing AppArmor.
searching on google I have found out that a recipe for Apparmor_2.11 exists in yocto/meta-security layer.
-So I have cloned the meta-security layer in <petalinux_source_dir>/components/yocto/source/arm/layers/
- I have downloaded the zip archive Apparmor_2.11.gz in <petalinux_source_dir>/components/yocto/downloads
-I have modified <petalinux_source_dir>/components/yocto/source/arm/lconf/bblayers.conf file and added the meta-security layer so it will permanently see the layer
- in project-spec/meta-user/recipes-core/images/petalinux-image.bbappend i have added
IMAGE_INSTALL_append = " apparmor"
and enable it petalinux-config -c rootfs->user packages->apparmor
2)Installing ArpOn
there is no recipe for ArpOn, so I have to cross compiled it in my petalinux project
-I have create a petalinux app with autoconf template
-I have copied the source files in project-spec/meta-user/recipes-apps/ArpOn/files
-now Arpon is complied with cmake, so in ArpOn.bb I have specified all include paths, library paths and dependencies needed
CMAKE_INCLUDE_PATH = "${D}/usr/include"
CMAKE_INCLUDE_PATH += "${D}/usr/local/include"
CMAKE_INCLUDE_PATH += "${D}/usr/local/include/libnet11"
CMAKE_INCLUDE_PATH += "${D}/usr/local/include/libnet-1.1"
CMAKE_LIBRARY_PATH = "${D}/usr/lib"
CMAKE_LIBRARY_PATH += "${D}/lib"
CMAKE_LIBRARY_PATH += "${D}/usr/lib32"
CMAKE_LIBRARY_PATH += "${D}/usr/lib34"
CMAKE_LIBRARY_PATH += "${D}/usr/local/lib"
CMAKE_LIBRARY_PATH += "${D}/usr/local/lib32"
CMAKE_LIBRARY_PATH += "${D}/usr/local/lib64"
CMAKE_LIBRARY_PATH += "${D}/usr/local/lib/libnet11"
CMAKE_LIBRARY_PATH += "${D}/usr/local/libnet-1.1"
DEPENDS = "libdnet"
RDEPENDS_${PN} += "libdnet"
RDEPENDS_${PN} += "libnet"
inherit cmake
 (note the "inherit cmake" and the absence of do_install)
and that's it!
2b) if your library is compile with make, the procedure is the same but you have to :
- in your .bb files you have to add the EXTRA_OECONF parameters needed by autoconf for your library and probably also CFLAGS_prepend and library flags as well
-edit the auto-generated Makefile.in in order to see all the files needed  and compile them in right order
I hope this will help
Observer ralphkw1
Since it will be locate in "project-spec/meta-user/recipes-apps/", it is very yocto/petalinux specific. I know how to program shared libraries in linux, in fact the library already exists in Petalinux 15.4, I am just trying to move it to 17.2 but the petalinux reference documentation only describes how to petalinux-create for apps and modules, not shared libraries.
Observer ralphkw1
This is a custom shared libarary I use for interprocess communication between my linux applications. It does not already exist in yocto git repo...
Observer ralphkw1
I don't know how to generate the .bb file and makefile in the first place. So general statements about EXTRA_OECONF and CFLAGS_prepend don't really help me. The library already exists and it is not an autoconf project. I am looking for a simple example .bb and makefile for shared library. I gather that for 16.4 there was a petalinux-create template for this, but it was removed after that. Not sure why.
Visitor eatnafou
Were you ever to find something equivalent to petalinux-create -t libs for 2017.2.  I am trying to do a similar thing as I port my stuff from 2016.2 to a the yocto based 2017.2
Refer http://www.wiki.xilinx.com/PetaLinux+Yocto+Tips to create libraries using yocto. If you have any questions let me know.
Sandeep
