cvpeck
KCU105 petalinux build problems
Hi all,
I hope someone can help as I am at a loss. I'm trying to build a petalinux system for a KCU105 board using Vivado 2019.2.1
I have used an example template and selected the customisable MicroBlaze design, selecting the KCU105 hardware.
When I export the hardware then start the petalinux configuration the petalinux build is failing.
petalinux-create -t project --template microblaze --force -n petalinux --source ../xilinx-kcu105-axi-full-v2019.2-final.bsp
cd petalinux/
petalinux-config --get-hw-description ../project_1/ --silentconfig
petalinux-config -c kernel
petalinux-build
I believe the key error is -
Error: /home/peckc/Documents/KCU105/petalinux/build/../components/plnx_workspace/device-tree/device-tree/kcu105.dtsi:5.1-10 Label or path iic_main not found
FATAL ERROR: Syntax error parsing input tree
I’m following the instructions from the BSP -
MICROBLAZE BSP generation steps:
This section explain about BSP generation steps.
1.	Create and Configure a project
		$ petalinux-create -t project --template microblaze --force -n <name of the project>
		$ petalinux-config --get-hw-description=<path to hdf directory> --oldconfig
		$ petalinux-config -c kernel
2.	Select following configs and save it.
		I2C_MUX
		EEPROM_AT24
		I2C_MUX_PCA954x
		I2C_CHARDEV
		COMMON_CLK_SI570
		CONFIG_TMPFS (enable for kcu105 design)
3.	Project Build
		$ petalinux-build
		$ mkdir -p pre-built/linux/images
		$ cp <project root>/images/linux/* <project root>/pre-built/linux/images/
4.	Package the BSP with files generated with following command
		$ petalinux-package --bsp -p <plnx-proj-root> --hwsource <hw-project-root> --output <name of the BSP>
NOTE: --hwsource is optional and can be removed
The full output is -
[INFO] building project
[INFO] sourcing bitbake
[INFO] generating user layers
[INFO] generating workspace directory
INFO: bitbake petalinux-user-image
Loading cache: 100% |#################################################################################################| Time: 0:00:00
Loaded 3979 entries from dependency cache.
Parsing recipes: 100% |###############################################################################################| Time: 0:00:03
Parsing of 2893 .bb files complete (2891 cached, 2 parsed). 3980 targets, 558 skipped, 0 masked, 0 errors.
NOTE: Resolving any missing task queue dependencies
WARNING: /opt/pkg/PetaLinux/components/yocto/source/microblaze_lite/layers/meta-xilinx/meta-xilinx-bsp/recipes-kernel/linux/linux-xlnx_2019.2.bb.do_compile is tainted from a forced run
Initialising tasks: 100% |############################################################################################| Time: 0:00:02
Checking sstate mirror object availability: 100% |####################################################################| Time: 0:00:32
Sstate summary: Wanted 771 Found 614 Missed 314 Current 35 (79% match, 80% complete)
NOTE: Executing SetScene Tasks
NOTE: Executing RunQueue Tasks
ERROR: device-tree-xilinx-v2019.2+gitAUTOINC+a8b39cf536-r0 do_compile: Error executing a python function in exec_python_func() autogenerated:
The stack trace of python calls that resulted in this exception/failure was:
File: 'exec_python_func() autogenerated', lineno: 2, function: <module>
     0001:
 *** 0002:devicetree_do_compile(d)
     0003:
File: '/opt/pkg/PetaLinux/components/yocto/source/microblaze_lite/layers/core/meta/classes/devicetree.bbclass', lineno: 131, function: devicetree_do_compile
     0127:            if not(os.path.isfile(dtspath)) or not(dts.endswith(".dts") or devicetree_source_is_overlay(dtspath)):
     0128:                continue # skip non-.dts files and non-overlay files
     0129:        except:
     0130:            continue # skip if can't determine if overlay
 *** 0131:        devicetree_compile(dtspath, includes, d)
     0132:}
     0133:
     0134:devicetree_do_install() {
     0135:    for DTB_FILE in `ls *.dtb *.dtbo`; do
File: '/opt/pkg/PetaLinux/components/yocto/source/microblaze_lite/layers/core/meta/classes/devicetree.bbclass', lineno: 119, function: devicetree_compile
     0115:        dtcargs += ["-i", i]
     0116:    dtcargs += ["-o", "{0}.{1}".format(dtname, "dtbo" if isoverlay else "dtb")]
     0117:    dtcargs += ["-I", "dts", "-O", "dtb", "{0}.pp".format(dts)]
     0118:    bb.note("Running {0}".format(" ".join(dtcargs)))
 *** 0119:    subprocess.run(dtcargs, check = True, stdout=subprocess.PIPE, stderr=subprocess.STDOUT)
     0120:
     0121:python devicetree_do_compile() {
     0122:    includes = expand_includes("DT_INCLUDE", d)
     0123:    listpath = d.getVar("DT_FILES_PATH")
File: '/opt/pkg/PetaLinux/components/yocto/source/microblaze_lite/buildtools/sysroots/x86_64-petalinux-linux/usr/lib/python3.5/subprocess.py', lineno: 398, function: run
     0394:            raise
     0395:        retcode = process.poll()
     0396:        if check and retcode:
     0397:            raise CalledProcessError(retcode, process.args,
 *** 0398:                                     output=stdout, stderr=stderr)
     0399:    return CompletedProcess(process.args, retcode, stdout, stderr)
     0400:
     0401:
     0402:def list2cmdline(seq):
Exception: subprocess.CalledProcessError: Command '['dtc', '-R', '8', '-b', '0', '-p', '0x1000', '-i', '/home/peckc/Documents/KCU105/petalinux/build/tmp/work/plnx_microblazeel-xilinx-linux/device-tree/xilinx-v2019.2+gitAUTOINC+a8b39cf536-r0', '-i', '/home/peckc/Documents/KCU105/petalinux/build/tmp/work-shared/plnx-microblazeel/kernel-source/arch/microblaze/boot/dts', '-i', '/home/peckc/Documents/KCU105/petalinux/build/tmp/work-shared/plnx-microblazeel/kernel-source/scripts/dtc/include-prefixes', '-i', '/home/peckc/Documents/KCU105/petalinux/build/../components/plnx_workspace/device-tree/device-tree', '-i', '/home/peckc/Documents/KCU105/petalinux/build/tmp/work-shared/plnx-microblazeel/kernel-source/include', '-o', 'system-top.dtb', '-I', 'dts', '-O', 'dtb', 'system-top.dts.pp']' returned non-zero exit status 1
Subprocess output:
ERROR: device-tree-xilinx-v2019.2+gitAUTOINC+a8b39cf536-r0 do_compile: Function failed: devicetree_do_compile
ERROR: Logfile of failure stored in: /home/peckc/Documents/KCU105/petalinux/build/tmp/work/plnx_microblazeel-xilinx-linux/device-tree/xilinx-v2019.2+gitAUTOINC+a8b39cf536-r0/temp/log.do_compile.10219
ERROR: Task (/opt/pkg/PetaLinux/components/yocto/source/microblaze_lite/layers/meta-xilinx/meta-xilinx-bsp/recipes-bsp/device-tree/device-tree.bb:do_compile) failed with exit code '1'
NOTE: Tasks Summary: Attempted 2685 tasks of which 2085 didn't need to be rerun and 1 failed.
Summary: 1 task failed:
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
ERROR: Failed to build project
stephenm
cd petalinux/
petalinux-build
So, you are using the BSP. This will populate the DTG Settings with kcu105. This will pull in the kcu105.dtsi file:
https://github.com/Xilinx/device-tree-xlnx/blob/master/device_tree/data/kernel_dtsi/2019.2/BOARD/kcu105.dtsi
Then you went and used a custom HDF file in the petalinux-config --get-hw-description step. This will create a new pl.dtsi based on your xsa/hdf. However, there
is no iic_main node here. So, when you are compiling in the DTC you are getting the error.
Also, why are you using the --template and the -s bsp? You don't need to do this. You can either use the BSP, or the template.
To fix your error, just go to petalinux-config -> DTG settings and remove the kcu105 and rebuild
smahalle
Hi @cvpeck,
Could you please share your HDF file.I would like to reproduce this issue at our end.
Thanks & Regards,
Shubhangu
stephenm
Can you check the pl.dtsi to make sure the label (iic_main) in the error message exists? Im guessing it doesnt.
cvpeck
Hi Shubhangu, Apologies for my delay in replying.
I've attached my exported hardware in an xsa file and a tcl script to recreate my project.
Chris
cvpeck
I've attached the pl.dtsi file. the iic_main label does not exist in the file. I'm unsure what that signifies.
Chris
stephenm
cd petalinux/
petalinux-build
cvpeck
It’s due to my lack of understanding, I’m pretty new at this.
Thanks for the reply. I’ll give that a go.
regards,
Chris
cvpeck
Thank you all for your patience and assistance. I can confirm that running the following fixed the issue -
petalinux-create -t project --force -n petalinux --source ../xilinx-kcu105-axi-full-v2019.2-final.bsp
#create project using supplied BSP file. Do not import hdf/xsa
cd petalinux/
#configure dtg to be KCU105
petalinux-config
petalinux-build
#boot into linux
petalinux-boot --qemu —kernel
