Visitor csporer
Kernel 4.19 hangs by reboot (Zynq700)
after changing from Kernel 4.14 to 4.19 I have the problem, that the kernel hangs at reboot:
[  OK  ] Reached target Reboot.
[   61.307069] systemd-shutdow: 29 output lines suppressed due to ratelimiting
[   61.346581] systemd-shutdown[1]: Syncing filesystems and block devices.
[   61.353506] systemd-shutdown[1]: Sending SIGTERM to remaining processes...
[   61.368289] systemd-journald[666]: Received SIGTERM from PID 1 (systemd-shutdow).
[   61.431060] systemd-shutdown[1]: Sending SIGKILL to remaining processes...
[   61.443445] systemd-shutdown[1]: Hardware watchdog 'cdns_wdt watchdog', version 0
[   61.453684] systemd-shutdown[1]: Unmounting file systems.
[   61.460176] systemd-shutdown[1]: All filesystems unmounted.
[   61.465829] systemd-shutdown[1]: Deactivating swaps.
[   61.470991] systemd-shutdown[1]: Failed to parse (null): No such file or directory
[   61.478572] systemd-shutdown[1]: Failed to deactivate swaps: No such file or directory
[   61.486720] systemd-shutdown[1]: Detaching loop devices.
[   61.521882] reboot: Restarting system
It looks the same as the output by the 4.14, but the old kernel resets to the uboot.
I compared the configs and in the 4.19 kernel the config CONFIG_VECTORS_BASE=0xffff0000 is missing.
Is that a problem? It feels like the reset address is missing?
After switching power off it starts normally.
Best regards
Visitor csporer
Re: Kernel 4.19 hangs by reboot (Zynq700)
Now I found the real problem!
In the m25p80 kernel driver is a bug in the shutdown function.
The history do not show the change to the false call, but that should be fixed in the kernel.
Here is the path:
diff -Naur a/drivers/mtd/devices/m25p80.c b/drivers/mtd/devices/m25p80.c
--- a/drivers/mtd/devices/m25p80.c	2019-12-02 16:49:19.000000000 +0100
+++ b/drivers/mtd/devices/m25p80.c	2019-12-02 16:51:18.634496771 +0100
@@ -265,7 +265,7 @@
 	struct m25p *flash = spi_mem_get_drvdata(spimem);
-	spi_nor_restore(&flash->spi_nor);
+	spi_nor_shutdown(&flash->spi_nor);
  * Do NOT add to this array without reading the following:
Best regards!
Visitor csporer
Here is the path:
@@ -265,7 +265,7 @@
Best regards!
