Observer apuls
Kernel Panic: Unable to mount root - booting from SDCard with active nand controller
Hi all,
we have a small problem in combination with NAND and SD card boot.
We use NAND as primary boot source and it works well as long as we do not plug in a SD card and change bootargs in UBOOT to boot from SD card.
 bootargs=console=ttyPS1,115200 root=/dev/mmcblk0p2 rootfstype=ext2 rw rootwait
NAND device: Manufacturer ID: 0x2c, Chip ID: 0xdc (Micron MT29F4G08ABADAH4), 512MiB, page size: 2048, OOB size: 64
Bad block table found at page 262080, version 0x01
Bad block table found at page 262016, version 0x01
5 ofpart partitions found on MTD device xilinx_nand
Creating 5 MTD partitions on "xilinx_nand":
0x000000000000-0x000000500000 : "uboot"
0x000000500000-0x000000600000 : "uboot-env"
0x000000600000-0x000000a00000 : "kernel"
0x000000a00000-0x000000b00000 : "devicetree"
0x000000b00000-0x00001ff00000 : "root"
TCP: cubic registered
drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
Waiting for root device /dev/mmcblk0p2...
usb 1-1: new high-speed USB device number 2 using xusbps-ehci
mmc0: new high speed SDHC card at address 0002
mmcblk0: mmc0:0002 00000 3.70 GiB (ro)
 mmcblk0: p1 p2
VFS: Cannot open root device "mmcblk0p2" or unknown-block(179,2): error -30
Please append a correct "root=" boot option; here are the available partitions:
1f00            5120 mtdblock0  (driver?)
1f01            1024 mtdblock1  (driver?)
1f02            4096 mtdblock2  (driver?)
1f03            1024 mtdblock3  (driver?)
1f04          512000 mtdblock4  (driver?)
b300         3880960 mmcblk0  driver: mmcblk
  b301          487840 mmcblk0p1 000e0aff-01
  b302         3390912 mmcblk0p2 000e0aff-02
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(179,2)
CPU1: stopping
Backtrace:
[<c001177c>] (dump_backtrace+0x0/0x10c) from [<c03fec70>] (dump_stack+0x18/0x1c)
 r6:c057e44c r5:00000000 r4:00000001 r3:60000193
[<c03fec58>] (dump_stack+0x0/0x1c) from [<c00134e8>] (ipi_cpu_stop+0x44/0x74)
[<c00134a4>] (ipi_cpu_stop+0x0/0x74) from [<c001378c>] (handle_IPI+0x64/0x84)
 r4:c0581ccc r3:c00134a4
[<c0013728>] (handle_IPI+0x0/0x84) from [<c0008570>] (gic_handle_irq+0x60/0x68)
 r5:ee075f68 r4:f8f00100
[<c0008510>] (gic_handle_irq+0x0/0x68) from [<c000dd80>] (__irq_svc+0x40/0x70)
Exception stack(0xee075f68 to 0xee075fb0)
5f60:                   c05a7d10 a0000193 00000001 00000000 ee074000 c0407ecc
5f80: ee074000 c05a7b78 0000406a 413fc090 00000000 ee075fbc ee075fc0 ee075fb0
5fa0: c000ece4 c000ece8 60000113 ffffffff
 r6:ffffffff r5:60000113 r4:c000ece8 r3:c000ece4
[<c000ecbc>] (default_idle+0x0/0x34) from [<c000eeb4>] (cpu_idle+0xac/0xfc)
[<c000ee08>] (cpu_idle+0x0/0xfc) from [<c03fc11c>] (secondary_start_kernel+0xdc/0xf0)
 r5:00000001 r4:c0588810
[<c03fc040>] (secondary_start_kernel+0x0/0xf0) from [<003fb70c>] (0x3fb70c)
 r6:10c0387d r5:00000015 r4:2e06006a r3:c03fb6f4
The point is disabling the NAND controller in our device tree let's it boot and work like a charm.
Any ideas?
Scholar milosoftware
Re: Kernel Panic: Unable to mount root - booting from SDCard with active nand controller
Configure and enable the "card detect" (CD pin) of the SD card. The default devicetree does NOT enable it, the SD driver seems to probe a bit too early without it, and then the SD doesn't work correctly.
Observer apuls
Sorry for my late response.
The CD Pin is enabled in our devicetree:
xlnx,has-cd = <0x1>;
The Card detect works under Linux. The Kernel prints a message if we remove or insert the Card.
I forgot to say that the SD Card Slot is a "microSD Slot".
We also tried to activate the WP "Feature"
xlnx,has-wp = <0x1>;
and set it via the PL to Logic 0 or Logic 1. The appropriate register bit was alway 0.
After removing the Nand Controller from the devicetree the WP Bit was 1 and we had write access.
Visitor r_vivek
Was this issue resolved I am facing the same issue, I am missing some configurations.
Vivek
Visitor r_vivek
Am i missing some configurations ??
My boards don't have any nand flash, so I can't really help with that. I can only suggest to double-check the pin assignments, it sounds like you have a conflict there. The "cd" missing has bit me once, so that's where my advice came from.
Observer apuls
Hey guys,
my college and me had to tweak the kernel a bit. Without tweaking we dind't get it to work.
Attached you will find a patch against the Xilinx Master Tree (3.9.0). As described above we are using micro sd card which don't have a "Lock Switch" so we disabled this function in the kernel.
r_vivek, hope that will help you too
kind regards
  andreas
The patch worked for me.
In 3.12.0 you'll find that sdhci-of-xilinxps.c was renamed to sdhci-of-arasan.c.
