Kernel doesn't come up - Hangs at Uncompressing Linux... done, booting the kernel on Zynq
Dear Xilinx community
Am seeing the below kernel hang issue which fails kernel to come up, could you please let me know how this issue can be resolved  I tried enablingthe following
CONFIG_DEBUG_LL=y
# CONFIG_DEBUG_VEXPRESS_UART0_DETECT is not set
# CONFIG_DEBUG_VEXPRESS_UART0_CA9 is not set
# CONFIG_DEBUG_VEXPRESS_UART0_RS1 is not set
# CONFIG_DEBUG_ZYNQ_UART0 is not set
CONFIG_DEBUG_ZYNQ_UART1=y
# CONFIG_DEBUG_ICEDCC is not set
# CONFIG_DEBUG_SEMIHOSTING is not set
# CONFIG_DEBUG_LL_UART_8250 is not set
# CONFIG_DEBUG_LL_UART_PL01X is not set
CONFIG_DEBUG_LL_INCLUDE="debug/zynq.S"
# CONFIG_DEBUG_UART_8250 is not set
CONFIG_DEBUG_UNCOMPRESS=y
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
CONFIG_EARLY_PRINTK=y
But still  dont see any reason why kernel is failing to come up logs as below
CONFIG_DEBUG_LL=y
Kindly do the needful as early as possible
Many Thanks in advance
Awaiting for your replies
Re: Kernel doesn't come up - Hangs at Uncompressing Linux... done, booting the kernel on Zynq
Sorry forgot to attach the logs those are as below
U-Boot 2013.04-00028-gf445610 (Mar 20 2017 - 17:45:46)
I2C:   ready
DRAM:  512 MiB
WARNING: Caches not enabled
NAND:  512 MiB
MMC:   zynq_sdhci: 0
SF: Detected S25FL512S_256K with page size 64 KiB, total 64 MiB
In:    serial
Out:   serial
Err:   serial
Net:   Gem.e000b000
Hit any key to stop autoboot:  0
zx3-pm3>
zx3-pm3>
zx3-pm3> setenv bootargs console=ttyPS0,115200n8 root=/dev/ram rw earlyprintk
zx3-pm3>
zx3-pm3>
zx3-pm3> fatload mmc 0 0x3000000 uImage;fatload mmc 0 0x2A00000 devicetree.dtb;fatload mmc 0 0x2000000 uramdisk.image.gz;bootm 0x3000000 0x2000000 0x2A00000
reading uImage
3535584 bytes read in 640 ms (5.3 MiB/s)
reading devicetree.dtb
10323 bytes read in 18 ms (559.6 KiB/s)
reading uramdisk.image.gz
8556246 bytes read in 1516 ms (5.4 MiB/s)
## Booting kernel from Legacy Image at 03000000 ...
   Image Name:   Linux-4.6.0-xilinx-22286-g2152fc
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3535520 Bytes = 3.4 MiB
   Load Address: 00008000
   Entry Point:  00008000
   Verifying Checksum ... OK
## Loading init Ramdisk from Legacy Image at 02000000 ...
   Image Name:
   Image Type:   ARM Linux RAMDisk Image (gzip compressed)
   Data Size:    8556182 Bytes = 8.2 MiB
   Load Address: 00000000
   Entry Point:  00000000
## Flattened Device Tree blob at 02a00000
   Booting using the fdt blob at 0x02a00000
   Loading Kernel Image ... OK
OK
   Loading Ramdisk to 1f30d000, end 1fb35e96 ... OK
   Loading Device Tree to 1f307000, end 1f30c852 ... OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
Dear Xilinx Experts,
Could you please provide any inputs w.r.t the above query as am stuck with this from past time
Thanks in advance
some more observation ie., Out of 10 times once the kernel boots and rest of the times it hangs at "uncompressing kernel"
U-Boot 2013.04-00028-g7c2ab7e-dirty (Apr 04 2017 - 17:01:37)
I2C: ready
DRAM: 512 MiB
Entering into XILINX_ZYNQ_7020!!!!!!!!!!!!
NAND: 512 MiB
MMC: zynq_sdhci: 0
In: serial
Out: serial
Err: serial
Net: Gem.e000b000
zx3-pm3>
zx3-pm3>
zx3-pm3>
reading uImage
3535592 bytes read in 640 ms (5.3 MiB/s)
7243 bytes read in 18 ms (392.6 KiB/s)
zx3-pm3> bootm 0x3000000 0x2000000
Data Size: 3535528 Bytes = 3.4 MiB
Image Name:
OK
Starting kernel ...
I2C: ready
DRAM: 512 MiB
NAND: 512 MiB
MMC: zynq_sdhci: 0
In: serial
Out: serial
Err: serial
Net: Gem.e000b000
Copying Linux from SD to RAM...
Device: zynq_sdhci
Manufacturer ID: 27
OEM: 5048
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading uImage
Image Name:
OK
Loading Device Tree to 1f308000, end 1f30cc4a ... OK
Starting kernel ...
init/main.c:477 set_task_stack_end_magic(&init_task);
init/main.c:479 smp_setup_processor_id();
init/main.c:481 debug_objects_early_init();
init/main.c:487 boot_init_stack_canary();
init/main.c:490 cgroup_init_early();
init/main.c:493 local_irq_disable();
init/main.c:495 early_boot_irqs_disabled = true;
init/main.c:504 boot_cpu_init();
init/main.c:506 page_address_init();
Linux version 4.6.0-xilinx-22286-g2152fc6-dirty (n008@n008-ThinkPad-L460) (gcc version 4.9.2 (Sourcery CodeBench Lite 2015.05-17) ) #0 SMP PREEMPT Tue Mar 7 14:28:25 CET 2017
init/main.c:510 setup_arch(&command_line);
Machine model: PTG Mars ZX3
Memory policy: Data cache writealloc
init/main.c:512 mm_init_owner(&init_mm, &init_task);
init/main.c:516 setup_command_line(command_line);
init/main.c:518 setup_nr_cpu_ids();
init/main.c:520 setup_per_cpu_areas();
percpu: Embedded 12 pages/cpu @dfbd7000 s19200 r8192 d21760 u49152
init/main.c:522 smp_prepare_boot_cpu();
init/main.c:524 build_all_zonelists(NULL, NULL);
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 130048
init/main.c:526 page_alloc_init();
Kernel command line: console=ttyPS0,115200
init/main.c:541 setup_log_buf(0);
init/main.c:543 pidhash_init();
PID hash table entries: 2048 (order: 1, 8192 bytes)
init/main.c:545 vfs_caches_init_early();
Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
init/main.c:547 sort_main_extable();
init/main.c:549 trap_init();
init/main.c:551 mm_init();
Memory: 502620K/524288K available (5282K kernel code, 232K rwdata, 1628K rodata, 1024K init, 189K bss, 21668K reserved, 0K cma-reserved, 0K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
.text : 0xc0008000 - 0xc07bf9b4 (7903 kB)
.init : 0xc0800000 - 0xc0900000 (1024 kB)
.data : 0xc0900000 - 0xc093a128 ( 233 kB)
.bss : 0xc093a128 - 0xc0969860 ( 190 kB)
init/main.c:570 idr_init_cache();
init/main.c:574 rcu_init();
Build-time adjustment of leaf fanout to 32.
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
init/main.c:576 radix_tree_init();
init/main.c:579 early_irq_init();
NR_IRQS:16 nr_irqs:16 16
init/main.c:581 init_IRQ();
ps7-slcr mapped to e0800000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
init/main.c:583 init_timers();
init/main.c:585 hrtimers_init();
init/main.c:587 softirq_init();
init/main.c:589 timekeeping_init();
init/main.c:591 time_init();
zynq_clock_init: clkc starts at e0800100
ZYNQ_CLKC_BASE!!!!!!!!!!!!!zynq_clock_init: clkc starts at e0800100
Zynq clock init
THE VALUE OF SLCR_SPI_CLK BEFORE WRITE!!!!!!!!!! 0x801
THE VALUE OF SLCR_SPI_CLK AFTER READ!!!!!!!!!! 0x801
arch/arm/mach-zynq/timer.c:301 clk_get_rate = 111111110
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
sched_clock: 16 bits at 54kHz, resolution 18432ns, wraps every 603975816ns
ps7-ttc #0 at e0808000, irq=17
init/main.c:593 profile_init();
init/main.c:595 call_function_init();
init/main.c:601 local_irq_enable();
init/main.c:604 kmem_cache_init_late();
init/main.c:616 lockdep_info();
init/main.c:636 page_ext_init();
init/main.c:638 debug_objects_mem_init();
init/main.c:640 kmemleak_init();
init/main.c:642 setup_per_cpu_pageset();
init/main.c:644 numa_policy_init();
init/main.c:648 sched_clock_init();
init/main.c:650 calibrate_delay();
Calibrating delay loop... 1332.01 BogoMIPS (lpj=6660096)
init/main.c:652 pidmap_init();
init/main.c:654 anon_vma_init();
init/main.c:660 thread_info_cache_init();
init/main.c:662 cred_init();
init/main.c:664 fork_init();
init/main.c:666 proc_caches_init();
init/main.c:668 buffer_init();
init/main.c:670 key_init();
init/main.c:672 security_init();
init/main.c:674 dbg_late_init();
init/main.c:676 vfs_caches_init(totalram_pages);
Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
init/main.c:678 signals_init();
init/main.c:685 cpuset_init();
init/main.c:687 cgroup_init();
init/main.c:689 taskstats_init_early();
init/main.c:691 delayacct_init();
init/main.c:694 check_bugs();
init/main.c:698 sfi_init_late();
init/main.c:706 ftrace_init();
init/main.c:710 rest_init();
Setting up static identity map for 0x100000 - 0x100034
Brought up 2 CPUs
SMP: Total of 2 processors activated (2664.03 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
GPIO IRQ not connected
XGpio: /amba@0/gpio@41200000: registered, base is 898
XGpio: /amba@0/gpio@41240000: registered, base is 890
vgaarb: loaded
SCSI subsystem initialized
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
FPGA manager framework
clocksource: Switched to clocksource ttc_clocksource
TCP established hash table entries: 4096 (order: 2, 16384 bytes)
TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
TCP: Hash tables configured (established 4096 bind 4096)
UDP hash table entries: 256 (order: 1, 8192 bytes)
UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
rootfs image is not initramfs (no cpio magic); looks like an initrd
Freeing initrd memory: 8356K (df30d000 - dfb36000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=28 max_order=17 bucket_order=0
fuse init (API version 7.24)
io scheduler noop registered
dma-pl330 f8003000.ps7-dma: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.ps7-dma: DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 155, base_baud = 6249999) is a xuartps
console [ttyPS0] enabled
xdevcfg f8007000.ps7-dev-cfg: ioremap 0xf8007000 to e085c000
brd: module loaded
loop: module loaded
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci-pci: EHCI PCI platform driver
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
softdog: Software Watchdog Timer: 0.08 initialized. soft_noboot=0 soft_margin=60 sec soft_panic=0 (nowayout=0)
usbcore: registered new interface driver ushc
mmc0: SDHCI controller on e0100000.ps7-sdio [e0100000.ps7-sdio] using ADMA
ledtrig-cpu: registered to indicate activity on CPUs
usbhid: USB HID core driver
hctosys: unable to open rtc device (rtc0)
RAMDISK: gzip image found at block 0
mmc0: new high speed SDHC card at address 0007
mmcblk0: mmc0:0007 SD8GB 7.42 GiB
mmcblk0: p1 p2
EXT4-fs (ram0): couldn't mount as ext3 due to feature incompatibilities
EXT4-fs (ram0): mounted filesystem with ordered data mode. Opts: (null)
VFS: Mounted root (ext4 filesystem) on device 1:0.
EXT4-fs (ram0): re-mounted. Opts: data=ordered
Starting logging: OK
Starting network: OK
Starting dropbear sshd: FAIL
Starting telnetd: OK
Starting rcS...
++ Mounting filesystem
++ Mounting SD Card
mount: mounting /dev/mmcblk0p1 on /mnt failed: No such file or directory
++ Setting up mdev
++ set path variable
++ Starting interfaces
ifconfig: SIOCSIFADDR: No such device
++ Starting dhcp client
mount: mounting devpts on /dev/pts failed: Device or resource busy
++ Starting http daemon
++ Starting ftp daemon
rcS Complete
/etc/init.d/S90inituser: line 83: tcpsvd: not found
Welcome to Buildroot
buildroot login: root
login[572]: root login on 'ttyPS0'
zync:~#
zync:~#
zync:~#
zync:~# cd /
zync:/#
I2C: ready
DRAM: 512 MiB
NAND: 512 MiB
MMC: zynq_sdhci: 0
In: serial
Out: serial
Err: serial
Net: Gem.e000b000
Device: zynq_sdhci
Manufacturer ID: 27
OEM: 5048
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 7.4 GiB
Bus Width: 4-bit
reading uImage
Image Name:
OK
Starting kernel ...
Could anybody please let me know why this inconsistent behavior is seen??
Eagerly awaiting for your replies
Dear Xilinx experts
Any updates on the above query as I was waiting for quite long time
Thanks in advance
May i know how it is resolved?
Prasanna G
Hi Srinivasan,
Please try with Default options without adding extra config options (Successful case) and then start adding  customised config options one after other , so that you can  identify the reason for Strange behaviour.
Thanks & regards
Satish.G
G Satish Kumar
