Scholar milosoftware
Kernel from 14.4 crash in xgpiops_irqhandler+0xb0/0x11c
Simplest way to reproduce this on a Zedboard is to map the push buttons GPIO to the gpio-keys driver, e.g. using the following fragment in the devicetree:
        gpio_keys {
            compatible = "gpio-keys";
            #address-cells = <1>;
            #size-cells = <0>;
            autorepeat;
            btn8 {
                label = "PB1";
                linux,code = <28>; // Enter
                gpios = <&gpio 50 0>;
            btn9 {
                label = "PB2";
                linux,code = <1>; // ESC
                gpios = <&gpio 51 0>;
Pushing the button then results in a kernel crash. Just "polling" the gpio pins works fine.
------------[ cut here ]------------
Kernel BUG at c01a59ec [verbose debug info unavailable]
Internal error: Oops - BUG: 0 [#1] PREEMPT SMP ARM
Modules linked in: ipv6 snd_soc_zed_adau1761 snd_soc_adi_axi_i2s regmap_mmio snd_soc_adv7511_hdmi sndc
CPU: 0    Not tainted  (3.6.0 #1)
PC is at xgpiops_irqhandler+0xb0/0x11c
LR is at xgpiops_irqhandler+0x9c/0x11c
pc : [<c01a59ec>]    lr : [<c01a59d8>]    psr: 60000193
sp : c04b1ed0  ip : 0000000f  fp : 00000000
r10: 00000034  r9 : c035b638  r8 : dccbd7c0
r7 : 00000001  r6 : 00000008  r5 : dccbd7f6  r4 : c04b3bc0
r3 : 00000000  r2 : 0000028c  r1 : 00000101  r0 : 00000000
Flags: nZCv  IRQs off  FIQs on  Mode SVC_32  ISA ARM  Segment kernel
Control: 18c5387d  Table: 1c51004a  DAC: 00000015
Process swapper/0 (pid: 0, stack limit = 0xc04b02f0)
Stack: (0xc04b1ed0 to 0xc04b2000)
1ec0:                                     00000034 00000000 c04c8474 c04b1f4c
1ee0: c04ccbc8 413fc090 00000000 c00618c0 00000034 c000e41c 00000034 c04b1f18
1f00: f8f00100 c0008404 c001b5f0 20000013 ffffffff c000d780 000c45f9 000003e8
1f20: 00000385 2ff1578e c090a358 00000000 c090a358 00000000 c04ccbc8 413fc090
1f40: 00000000 00000000 2ff15466 c04b1f60 c004b4e4 c001b5f0 20000013 ffffffff
1f60: 77359400 c090a358 00000385 000c0c84 00000385 000c45f9 c090a358 00000000
1f80: c090a358 c026ae98 c026ae84 c026b28c c090a358 00000000 c04feac4 c026b384
1fa0: c04b0000 c0346ca0 c04e9588 c0907000 0000406a c000e880 c04c8ac0 c04b0000
1fc0: c04a7b00 c048d718 ffffffff ffffffff c048d284 00000000 00000000 c04a7b00
1fe0: 00000000 18c5387d c04c844c c04a7af8 c04cbc8c 0000803c 00000000 00000000
[<c01a59ec>] (xgpiops_irqhandler+0xb0/0x11c) from [<c00618c0>] (generic_handle_irq+0x20/0x30)
[<c00618c0>] (generic_handle_irq+0x20/0x30) from [<c000e41c>] (handle_IRQ+0x78/0xb8)
[<c000e41c>] (handle_IRQ+0x78/0xb8) from [<c0008404>] (gic_handle_irq+0x3c/0x60)
[<c0008404>] (gic_handle_irq+0x3c/0x60) from [<c000d780>] (__irq_svc+0x40/0x70)
Exception stack(0xc04b1f18 to 0xc04b1f60)
1f00:                                                       000c45f9 000003e8
[<c000d780>] (__irq_svc+0x40/0x70) from [<c001b5f0>] (xilinx_enter_idle+0x7c/0xb0)
[<c001b5f0>] (xilinx_enter_idle+0x7c/0xb0) from [<c026ae98>] (cpuidle_enter+0x14/0x18)
[<c026ae98>] (cpuidle_enter+0x14/0x18) from [<c026b28c>] (cpuidle_enter_state+0x14/0x68)
[<c026b28c>] (cpuidle_enter_state+0x14/0x68) from [<c026b384>] (cpuidle_idle_call+0xa4/0xf0)
[<c026b384>] (cpuidle_idle_call+0xa4/0xf0) from [<c000e880>] (cpu_idle+0x80/0xe0)
[<c000e880>] (cpu_idle+0x80/0xe0) from [<c048d718>] (start_kernel+0x268/0x2a8)
Code: 0a000002 e5933010 e3530000 1a000000 (e7f001f2)
Re: Kernel from 14.4 crash in xgpiops_irqhandler+0xb0/0x11c
Looks like it might be a duplicate of this issue https://github.com/Xilinx/linux-xlnx/issues/3 , which has been fixed with this commit https://github.com/Xilinx/linux-xlnx/commit/ca2d4f14bf5e5943cd09776cee4a7e1a4d57f400 .
Please try if this fixes your problem.
Cherry-picked that commit and rebuilt, indeed fixes the crash. Thanx!
