senkoo
Kernel hangs at "starting kernel..." *UPDATED*
My name is Senna and I am working on a zc702 dev kit.
You're probably tired of reading "Kernel hangs ..." but I've read a lot of posts about it but i couldn't really find the solution for my situation.
The problem now is when i add my applications the the rootfs then it gets stuck. Also when i when i deselect my apps and actually apply a patch to the kernel it also doesnt go past starting kernel..
I have modified xilinx_emacps.c and fixed_phy.c since my board does not have a physical ethernet switch. Then i went and looked in the forums on how to modify the kernel source so i did that. I made a patch file named: 0001-ethernet.patch and put this in the linux-xlnx_%append.bb file under the src files. It compiles and builds but then after i have programmed system.dtb image.ub and BOOT.BIN to the SPI flash memory and i boot it it hangs.
First of all it is really slow? I need to say that also. It takes alot of time to load from flash and i cant remember it taking so long before, but that may be irrelevant.
As i said i wasn't lazy and just posted i actually tried reading the other posts and solutions but i did not find my correct answer. (Or maybe i just overlooked it, in that case im sorry for asking this problem once again :p)
Thanks in advance.
Senna
Kernel log
U-Boot 2017.01 (Oct 05 2018 - 06:14:15 +0000)
Board: Xilinx Zynq
DRAM:  ECC disabled 1 GiB
MMC:   sdhci_transfer_data: Error detected in status(0x208000)!
sdhci@e0101000: 0 (eMMC)
SF: Detected n25q1024 with page size 256 Bytes, erase size 4 KiB, total 128 MiB
In:    serial
Out:   serial
Err:   serial
Net:   ZYNQ GEM: e000b000, phyaddr ffffffff, interface rgmii-id
PHY is not detected
GEM PHY init failed
No ethernet found.
U-BOOT for ets-prg
Zynq> sf probe
Zynq> sf write 0x1000000 0x0 0x500000
device 0 offset 0x0, size 0x500000
SF: 5242880 bytes @ 0x0 Written: OK
Zynq> sf write 0x2000000 0x520000 0x50000
device 0 offset 0x520000, size 0x50000
SF: 327680 bytes @ 0x520000 Written: OK
Zynq> sf write 0x3000000 0x570000 0x1500000
device 0 offset 0x570000, size 0x1500000
SF: 22020096 bytes @ 0x570000 Written: OK
Zynq> boot
SF: 22020096 bytes @ 0x570000 Read: OK
## Loading kernel from FIT Image at 01000000 ...
   Using 'conf@1' configuration
   Verifying Hash Integrity ... OK
   Trying 'kernel@0' kernel subimage
     Description:  Linux Kernel
     Type:         Kernel Image
     Compression:  uncompressed
     Data Start:   0x010000d4
     Data Size:    1992312 Bytes = 1.9 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: 0x00008000
     Entry Point:  0x00008000
     Hash algo:    sha1
     Hash value:   9e2f32b439080613643ba1347c97a2a00c2c1967
## Loading ramdisk from FIT Image at 01000000 ...
   Trying 'ramdisk@0' ramdisk subimage
     Description:  ramdisk
     Type:         RAMDisk Image
     Data Start:   0x011e9eac
     Data Size:    8524797 Bytes = 8.1 MiB
     Architecture: ARM
     OS:           Linux
     Load Address: unavailable
     Entry Point:  unavailable
     Hash algo:    sha1
     Hash value:   c776313e41b22ba85ebaec5ee0b222a1aaade165
## Loading fdt from FIT Image at 01000000 ...
   Trying 'fdt@0' fdt subimage
     Description:  Flattened Device Tree blob
     Type:         Flat Device Tree
     Data Start:   0x011e6840
     Data Size:    13753 Bytes = 13.4 KiB
     Architecture: ARM
     Hash algo:    sha1
     Hash value:   8dd3b6d44998f9d3689ec732e7f96e84e7adf973
   Booting using the fdt blob at 0x11e6840
mdio_register: non unique device name 'eth0'
   Loading Kernel Image ... OK
   Loading Ramdisk to 077de000, end 07fff3fd ... OK
   Loading Device Tree to 077d7000, end 077dd5b8 ... OK
Starting kernel ...
deville
I had the same a couple of days ago.  I found it useful to enable the early debug prints of the kernel, then you'll see more of what is going on.
petalinux-config -c kernel
Then enable:
Kernel hacking -> [*] Kernel low-level debugging functions -> Xilinx zynq Uart1
Kernel hacking -> [*] Early printk
In my case it had something to do with U boot placing the dtb files high up in memory while linux could not reach this. Therefore I decreased the memory in the uboot dtb files.
I'm not sure if this is an accepted way of doing things, but I got through while booting
senkoo
Hi @deville,
Thank you for your response. The strange thing is that I had a working version on GIT. After seeing that the kernel got stuck I simply started from that GIT commit again. But now that version also hangs at starting kernel....
I'm completly lost...
Greetings,
Senna
deville
@senkoo
Can you rebuild your kernel and post the outcome here? You should definite see some more debug messages come trough your Uart serial device.
senkoo
Hi @deville,
i have figured out that it has something to do with my apps. I try to fix it now. If i include the apps it doesnt boot after starting kernel...
Mind is blown right now :P
Cheers.
