Kernel module insmod error "Invalid module Format"
I tried to compile sample kernel module and then run "insmod hello.ko" in target board.
but  I met a error "Invalid module Format"
I check other system module and my sample module using modinfo.
but it's same  as below. Please advise me..
target board module info
# modinfo ./libcomposite.ko
filename: ./libcomposite.ko
author: David Brownell
license: GPL
depends:
intree: Y
vermagic: 4.19.0-xilinx-v2019.1 SMP preempt mod_unload modversions ARMv7 p2v8
my sample module
$ modinfo hello.ko
filename: /hello.ko
description: Hello world for Linux Kernel module
author: sj
license: GPL
depends:
dmesg log
disagrees about version of sysmbol module_layout
Tags (2)
Re: Kernel module insmod error "Invalid module Format"
Solved this
I changed  kernel menuconfig
I did uncheck this option, then It's done
"Enable lodable module support" >> "Module versioning support"
Solved this
