rsummers
Kernel panic in petalinux on boot in hardware, but not in QEMU
I'm trying to get petalinux to run on a microblaze processor in a VC707 board, but have been unable to get it to boot in hardware due to the kernel panic shown in the attached screenshot. Interestingly, the error only occurs in hardware, and petalinux boots fine in QEMU. Being mentioned in one of the last lines that I'm able to somewhat read, I've checked over everything relating to the UART that I can think of, but all of the settings topically look correct. I've also tried baud rates of both 9600 and 115200, and the same error occurs for both settings. If anybody has any pointers for how I can get this processor working, it would be much appreciated.
If it is of any use, some device tree files are also attached with modified extensions to make the forum attachment system happy.
Thanks!
