Kernel panic - not syncing: Fatal exception in interrupt
Hi, all,
I use the DN8000K10PCI from dini group. I'm trying to install Xilinx Open Linux on the Virtex4 FX100-12. My dts file is pasted below:
/dts-v1/; / { #address-cells = <1>; #size-cells = <1>; compatible = "xlnx,virtex405", "xlnx,virtex"; model = "testing"; DDR2_SDRAM: memory@0 { device_type = "memory"; reg = < 0x0 0x40000000 >; } ; aliases { serial0 = &RS232_Uart_1; } ; chosen { bootargs = "console=ttyUL0 root=/dev/ram"; linux,stdout-path = "/plb@0/serial@84000000"; } ; cpus { #address-cells = <1>; #cpus = <0x1>; #size-cells = <0>; ppc405_0: cpu@0 { clock-frequency = <300000000>; compatible = "PowerPC,405", "ibm,ppc405"; d-cache-line-size = <0x20>; d-cache-size = <0x4000>; dcr-access-method = "native"; dcr-controller ; device_type = "cpu"; i-cache-line-size = <0x20>; i-cache-size = <0x4000>; model = "PowerPC,405"; reg = <0>; timebase-frequency = <300000000>; xlnx,apu-control = <0xde00>; xlnx,apu-udi-1 = <0xa18983>; xlnx,apu-udi-2 = <0xa38983>; xlnx,apu-udi-3 = <0xa589c3>; xlnx,apu-udi-4 = <0xa789c3>; xlnx,apu-udi-5 = <0xa98c03>; xlnx,apu-udi-6 = <0xab8c03>; xlnx,apu-udi-7 = <0xad8c43>; xlnx,apu-udi-8 = <0xaf8c43>; xlnx,deterministic-mult = <0x0>; xlnx,disable-operand-forwarding = <0x1>; xlnx,fastest-plb-clock = "DPLB0"; xlnx,generate-plb-timespecs = <0x1>; xlnx,mmu-enable = <0x1>; xlnx,pvr-high = <0x0>; xlnx,pvr-low = <0x0>; } ; } ; plb: plb@0 { #address-cells = <1>; #size-cells = <1>; compatible = "xlnx,plb-v46-1.04.a", "xlnx,plb-v46-1.00.a", "simple-bus"; ranges ; LEDs_8Bit: gpio@81400000 { compatible = "xlnx,xps-gpio-2.00.a", "xlnx,xps-gpio-1.00.a"; interrupt-parent = <&xps_intc_0>; interrupts = < 0 2 >; reg = < 0x81400000 0x10000 >; xlnx,all-inputs = <0x0>; xlnx,all-inputs-2 = <0x0>; xlnx,dout-default = <0x0>; xlnx,dout-default-2 = <0x0>; xlnx,family = "virtex4"; xlnx,gpio-width = <0x8>; xlnx,gpio2-width = <0x20>; xlnx,interrupt-present = <0x1>; xlnx,is-dual = <0x0>; xlnx,tri-default = <0xffffffff>; xlnx,tri-default-2 = <0xffffffff>; } ; RS232_Uart_1: serial@84000000 { clock-frequency = <100000000>; compatible = "xlnx,xps-uartlite-1.01.a", "xlnx,xps-uartlite-1.00.a"; current-speed = <9600>; device_type = "serial"; interrupt-parent = <&xps_intc_0>; interrupts = < 1 0 >; port-number = <0>; reg = < 0x84000000 0x10000 >; xlnx,baudrate = <0x2580>; xlnx,data-bits = <0x8>; xlnx,family = "virtex4"; xlnx,odd-parity = <0x0>; xlnx,use-parity = <0x0>; } ; mpmc@0 { #address-cells = <1>; #size-cells = <1>; compatible = "xlnx,mpmc-5.02.a"; } ; xps_bram_if_cntlr_1: xps-bram-if-cntlr@fffe0000 { compatible = "xlnx,xps-bram-if-cntlr-1.00.b", "xlnx,xps-bram-if-cntlr-1.00.a"; reg = < 0xfffe0000 0x20000 >; xlnx,family = "virtex4"; } ; xps_intc_0: interrupt-controller@81800000 { #interrupt-cells = <0x2>; compatible = "xlnx,xps-intc-2.00.a", "xlnx,xps-intc-1.00.a"; interrupt-controller ; reg = < 0x81800000 0x10000 >; xlnx,num-intr-inputs = <0x2>; } ; } ; ppc405_0_dplb1: plb@1 { #address-cells = <1>; #size-cells = <1>; compatible = "xlnx,plb-v46-1.04.a", "xlnx,plb-v46-1.00.a", "simple-bus"; ranges ; } ; } ;
The Uartlite is enabled in the kernel. (The reason I have to use Uartlite is because the board datasheet only tells two pins of rs232, rx and tx. If I use uart16550, I have to specifiy cts and rts pins which I'm not told.)
The kernel booting message got hung as showing below:
Linux/PowerPC load: console=ttyUL0 root=/dev/ram Finalizing device tree... flat tree at 0x720300
When I resize the ramdisk to 16M, and modify the default kernel configuration file after patch with 40x/virtex4-defconfig accordingly. I manage to boot the kernel, but still with error. The kernel config shows below:
# # Automatically generated make config: don't edit # Linux kernel version: 2.6.30 # Wed Sep 16 12:41:32 2009 # # CONFIG_PPC64 is not set # # Processor support # # CONFIG_6xx is not set # CONFIG_PPC_85xx is not set # CONFIG_PPC_8xx is not set CONFIG_40x=y # CONFIG_44x is not set # CONFIG_E200 is not set CONFIG_4xx=y CONFIG_PPC_MMU_NOHASH=y # CONFIG_PPC_MM_SLICES is not set CONFIG_NOT_COHERENT_CACHE=y CONFIG_PPC32=y CONFIG_WORD_SIZE=32 # CONFIG_ARCH_PHYS_ADDR_T_64BIT is not set CONFIG_MMU=y CONFIG_GENERIC_CMOS_UPDATE=y CONFIG_GENERIC_TIME=y CONFIG_GENERIC_TIME_VSYSCALL=y CONFIG_GENERIC_CLOCKEVENTS=y CONFIG_GENERIC_HARDIRQS=y # CONFIG_HAVE_SETUP_PER_CPU_AREA is not set CONFIG_IRQ_PER_CPU=y CONFIG_STACKTRACE_SUPPORT=y CONFIG_HAVE_LATENCYTOP_SUPPORT=y CONFIG_LOCKDEP_SUPPORT=y CONFIG_RWSEM_XCHGADD_ALGORITHM=y CONFIG_ARCH_HAS_ILOG2_U32=y CONFIG_GENERIC_HWEIGHT=y CONFIG_GENERIC_CALIBRATE_DELAY=y CONFIG_GENERIC_FIND_NEXT_BIT=y # CONFIG_ARCH_NO_VIRT_TO_BUS is not set CONFIG_PPC=y CONFIG_EARLY_PRINTK=y CONFIG_GENERIC_NVRAM=y CONFIG_SCHED_OMIT_FRAME_POINTER=y CONFIG_ARCH_MAY_HAVE_PC_FDC=y CONFIG_PPC_OF=y CONFIG_OF=y CONFIG_PPC_UDBG_16550=y # CONFIG_GENERIC_TBSYNC is not set CONFIG_AUDIT_ARCH=y CONFIG_GENERIC_BUG=y CONFIG_DTC=y CONFIG_DEFAULT_UIMAGE=y CONFIG_PPC_DCR_NATIVE=y CONFIG_PPC_DCR_MMIO=y CONFIG_PPC_DCR=y CONFIG_ARCH_SUPPORTS_DEBUG_PAGEALLOC=y CONFIG_DEFCONFIG_LIST="/lib/modules/$UNAME_RELEASE/.config" # # General setup # CONFIG_EXPERIMENTAL=y CONFIG_BROKEN_ON_SMP=y CONFIG_LOCK_KERNEL=y CONFIG_INIT_ENV_ARG_LIMIT=32 CONFIG_LOCALVERSION="" # CONFIG_LOCALVERSION_AUTO is not set CONFIG_SWAP=y CONFIG_SYSVIPC=y CONFIG_SYSVIPC_SYSCTL=y CONFIG_POSIX_MQUEUE=y CONFIG_POSIX_MQUEUE_SYSCTL=y # CONFIG_BSD_PROCESS_ACCT is not set # CONFIG_TASKSTATS is not set # CONFIG_AUDIT is not set # # RCU Subsystem # CONFIG_CLASSIC_RCU=y # CONFIG_TREE_RCU is not set # CONFIG_PREEMPT_RCU is not set # CONFIG_TREE_RCU_TRACE is not set # CONFIG_PREEMPT_RCU_TRACE is not set CONFIG_IKCONFIG=y CONFIG_IKCONFIG_PROC=y CONFIG_LOG_BUF_SHIFT=14 # CONFIG_GROUP_SCHED is not set # CONFIG_CGROUPS is not set CONFIG_SYSFS_DEPRECATED=y CONFIG_SYSFS_DEPRECATED_V2=y # CONFIG_RELAY is not set CONFIG_NAMESPACES=y # CONFIG_UTS_NS is not set # CONFIG_IPC_NS is not set # CONFIG_USER_NS is not set # CONFIG_PID_NS is not set # CONFIG_NET_NS is not set CONFIG_BLK_DEV_INITRD=y CONFIG_INITRAMFS_SOURCE="" CONFIG_RD_GZIP=y CONFIG_RD_BZIP2=y CONFIG_RD_LZMA=y # CONFIG_CC_OPTIMIZE_FOR_SIZE is not set CONFIG_SYSCTL=y CONFIG_ANON_INODES=y # CONFIG_EMBEDDED is not set CONFIG_SYSCTL_SYSCALL=y CONFIG_KALLSYMS=y # CONFIG_KALLSYMS_EXTRA_PASS is not set # CONFIG_STRIP_ASM_SYMS is not set CONFIG_HOTPLUG=y CONFIG_PRINTK=y CONFIG_BUG=y CONFIG_ELF_CORE=y CONFIG_BASE_FULL=y CONFIG_FUTEX=y CONFIG_EPOLL=y CONFIG_SIGNALFD=y CONFIG_TIMERFD=y CONFIG_EVENTFD=y CONFIG_SHMEM=y CONFIG_AIO=y CONFIG_VM_EVENT_COUNTERS=y CONFIG_PCI_QUIRKS=y CONFIG_COMPAT_BRK=y CONFIG_SLAB=y # CONFIG_SLUB is not set # CONFIG_SLOB is not set # CONFIG_PROFILING is not set # CONFIG_MARKERS is not set CONFIG_HAVE_OPROFILE=y # CONFIG_KPROBES is not set CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y CONFIG_HAVE_IOREMAP_PROT=y CONFIG_HAVE_KPROBES=y CONFIG_HAVE_KRETPROBES=y CONFIG_HAVE_ARCH_TRACEHOOK=y # CONFIG_SLOW_WORK is not set # CONFIG_HAVE_GENERIC_DMA_COHERENT is not set CONFIG_SLABINFO=y CONFIG_RT_MUTEXES=y CONFIG_BASE_SMALL=0 CONFIG_MODULES=y # CONFIG_MODULE_FORCE_LOAD is not set CONFIG_MODULE_UNLOAD=y CONFIG_MODULE_FORCE_UNLOAD=y CONFIG_MODVERSIONS=y # CONFIG_MODULE_SRCVERSION_ALL is not set CONFIG_BLOCK=y # CONFIG_LBD is not set # CONFIG_BLK_DEV_BSG is not set # CONFIG_BLK_DEV_INTEGRITY is not set # # IO Schedulers # CONFIG_IOSCHED_NOOP=y CONFIG_IOSCHED_AS=y CONFIG_IOSCHED_DEADLINE=y CONFIG_IOSCHED_CFQ=y # CONFIG_DEFAULT_AS is not set # CONFIG_DEFAULT_DEADLINE is not set CONFIG_DEFAULT_CFQ=y # CONFIG_DEFAULT_NOOP is not set CONFIG_DEFAULT_IOSCHED="cfq" # CONFIG_FREEZER is not set # CONFIG_PPC4xx_PCI_EXPRESS is not set # # Platform support # # CONFIG_PPC_CELL is not set # CONFIG_PPC_CELL_NATIVE is not set # CONFIG_PQ2ADS is not set # CONFIG_PPC4xx_GPIO is not set CONFIG_XILINX_VIRTEX=y # CONFIG_ACADIA is not set # CONFIG_EP405 is not set # CONFIG_HCU4 is not set # CONFIG_KILAUEA is not set # CONFIG_MAKALU is not set # CONFIG_WALNUT is not set CONFIG_XILINX_VIRTEX_GENERIC_BOARD=y # CONFIG_PPC40x_SIMPLE is not set CONFIG_XILINX_VIRTEX_II_PRO=y CONFIG_XILINX_VIRTEX_4_FX=y CONFIG_IBM405_ERR77=y CONFIG_IBM405_ERR51=y # CONFIG_IPIC is not set # CONFIG_MPIC is not set # CONFIG_MPIC_WEIRD is not set # CONFIG_PPC_I8259 is not set # CONFIG_PPC_RTAS is not set # CONFIG_MMIO_NVRAM is not set # CONFIG_PPC_MPC106 is not set # CONFIG_PPC_970_NAP is not set # CONFIG_PPC_INDIRECT_IO is not set # CONFIG_GENERIC_IOMAP is not set # CONFIG_CPU_FREQ is not set # CONFIG_FSL_ULI1575 is not set # CONFIG_SIMPLE_GPIO is not set # # Kernel options # # CONFIG_HIGHMEM is not set # CONFIG_NO_HZ is not set # CONFIG_HIGH_RES_TIMERS is not set CONFIG_GENERIC_CLOCKEVENTS_BUILD=y # CONFIG_HZ_100 is not set CONFIG_HZ_250=y # CONFIG_HZ_300 is not set # CONFIG_HZ_1000 is not set CONFIG_HZ=250 # CONFIG_SCHED_HRTICK is not set # CONFIG_PREEMPT_NONE is not set # CONFIG_PREEMPT_VOLUNTARY is not set CONFIG_PREEMPT=y CONFIG_BINFMT_ELF=y # CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS is not set # CONFIG_HAVE_AOUT is not set # CONFIG_BINFMT_MISC is not set CONFIG_MATH_EMULATION=y # CONFIG_IOMMU_HELPER is not set CONFIG_PPC_NEED_DMA_SYNC_OPS=y CONFIG_ARCH_ENABLE_MEMORY_HOTPLUG=y CONFIG_ARCH_HAS_WALK_MEMORY=y CONFIG_ARCH_ENABLE_MEMORY_HOTREMOVE=y CONFIG_ARCH_FLATMEM_ENABLE=y CONFIG_ARCH_POPULATES_NODE_MAP=y CONFIG_SELECT_MEMORY_MODEL=y CONFIG_FLATMEM_MANUAL=y # CONFIG_DISCONTIGMEM_MANUAL is not set # CONFIG_SPARSEMEM_MANUAL is not set CONFIG_FLATMEM=y CONFIG_FLAT_NODE_MEM_MAP=y CONFIG_PAGEFLAGS_EXTENDED=y CONFIG_SPLIT_PTLOCK_CPUS=4 CONFIG_MIGRATION=y # CONFIG_PHYS_ADDR_T_64BIT is not set CONFIG_ZONE_DMA_FLAG=1 CONFIG_BOUNCE=y CONFIG_VIRT_TO_BUS=y CONFIG_UNEVICTABLE_LRU=y CONFIG_HAVE_MLOCK=y CONFIG_HAVE_MLOCKED_PAGE_BIT=y CONFIG_PPC_4K_PAGES=y # CONFIG_PPC_16K_PAGES is not set # CONFIG_PPC_64K_PAGES is not set # CONFIG_PPC_256K_PAGES is not set CONFIG_FORCE_MAX_ZONEORDER=11 CONFIG_PROC_DEVICETREE=y CONFIG_CMDLINE_BOOL=y CONFIG_CMDLINE="" CONFIG_EXTRA_TARGETS="simpleImage.virtex405-ml405 simpleImage.initrd.virtex405-ml405" # CONFIG_PM is not set CONFIG_SECCOMP=y # CONFIG_COMPRESSED_DEVICE_TREE is not set CONFIG_ISA_DMA_API=y # # Bus options # CONFIG_ZONE_DMA=y CONFIG_PPC_INDIRECT_PCI=y CONFIG_4xx_SOC=y CONFIG_PPC_PCI_CHOICE=y CONFIG_PCI=y CONFIG_PCI_DOMAINS=y CONFIG_PCI_SYSCALL=y # CONFIG_PCIEPORTBUS is not set CONFIG_ARCH_SUPPORTS_MSI=y # CONFIG_PCI_MSI is not set CONFIG_PCI_LEGACY=y # CONFIG_PCI_STUB is not set # CONFIG_PCI_IOV is not set # CONFIG_PCCARD is not set # CONFIG_HOTPLUG_PCI is not set # CONFIG_HAS_RAPIDIO is not set # # Advanced setup # # CONFIG_ADVANCED_OPTIONS is not set # # Default settings for advanced configuration options are used # CONFIG_LOWMEM_SIZE=0x30000000 CONFIG_PAGE_OFFSET=0xc0000000 CONFIG_KERNEL_START=0xc0000000 CONFIG_PHYSICAL_START=0x00000000 CONFIG_TASK_SIZE=0xc0000000 CONFIG_CONSISTENT_SIZE=0x00200000 CONFIG_NET=y # # Networking options # CONFIG_PACKET=y # CONFIG_PACKET_MMAP is not set CONFIG_UNIX=y CONFIG_XFRM=y # CONFIG_XFRM_USER is not set # CONFIG_XFRM_SUB_POLICY is not set # CONFIG_XFRM_MIGRATE is not set # CONFIG_XFRM_STATISTICS is not set # CONFIG_NET_KEY is not set CONFIG_INET=y CONFIG_IP_MULTICAST=y # CONFIG_IP_ADVANCED_ROUTER is not set CONFIG_IP_FIB_HASH=y CONFIG_IP_PNP=y CONFIG_IP_PNP_DHCP=y CONFIG_IP_PNP_BOOTP=y # CONFIG_IP_PNP_RARP is not set # CONFIG_NET_IPIP is not set # CONFIG_NET_IPGRE is not set # CONFIG_IP_MROUTE is not set # CONFIG_ARPD is not set # CONFIG_SYN_COOKIES is not set # CONFIG_INET_AH is not set # CONFIG_INET_ESP is not set # CONFIG_INET_IPCOMP is not set # CONFIG_INET_XFRM_TUNNEL is not set CONFIG_INET_TUNNEL=m CONFIG_INET_XFRM_MODE_TRANSPORT=y CONFIG_INET_XFRM_MODE_TUNNEL=y CONFIG_INET_XFRM_MODE_BEET=y # CONFIG_INET_LRO is not set CONFIG_INET_DIAG=y CONFIG_INET_TCP_DIAG=y # CONFIG_TCP_CONG_ADVANCED is not set CONFIG_TCP_CONG_CUBIC=y CONFIG_DEFAULT_TCP_CONG="cubic" # CONFIG_TCP_MD5SIG is not set CONFIG_IPV6=m # CONFIG_IPV6_PRIVACY is not set # CONFIG_IPV6_ROUTER_PREF is not set # CONFIG_IPV6_OPTIMISTIC_DAD is not set # CONFIG_INET6_AH is not set # CONFIG_INET6_ESP is not set # CONFIG_INET6_IPCOMP is not set # CONFIG_IPV6_MIP6 is not set # CONFIG_INET6_XFRM_TUNNEL is not set # CONFIG_INET6_TUNNEL is not set CONFIG_INET6_XFRM_MODE_TRANSPORT=m CONFIG_INET6_XFRM_MODE_TUNNEL=m CONFIG_INET6_XFRM_MODE_BEET=m # CONFIG_INET6_XFRM_MODE_ROUTEOPTIMIZATION is not set CONFIG_IPV6_SIT=m CONFIG_IPV6_NDISC_NODETYPE=y # CONFIG_IPV6_TUNNEL is not set # CONFIG_IPV6_MULTIPLE_TABLES is not set # CONFIG_IPV6_MROUTE is not set # CONFIG_NETWORK_SECMARK is not set CONFIG_NETFILTER=y # CONFIG_NETFILTER_DEBUG is not set CONFIG_NETFILTER_ADVANCED=y # # Core Netfilter Configuration # # CONFIG_NETFILTER_NETLINK_QUEUE is not set # CONFIG_NETFILTER_NETLINK_LOG is not set # CONFIG_NF_CONNTRACK is not set # CONFIG_NETFILTER_TPROXY is not set CONFIG_NETFILTER_XTABLES=m # CONFIG_NETFILTER_XT_TARGET_CLASSIFY is not set # CONFIG_NETFILTER_XT_TARGET_DSCP is not set # CONFIG_NETFILTER_XT_TARGET_HL is not set # CONFIG_NETFILTER_XT_TARGET_MARK is not set # CONFIG_NETFILTER_XT_TARGET_NFLOG is not set # CONFIG_NETFILTER_XT_TARGET_NFQUEUE is not set # CONFIG_NETFILTER_XT_TARGET_RATEEST is not set # CONFIG_NETFILTER_XT_TARGET_TCPMSS is not set # CONFIG_NETFILTER_XT_TARGET_TCPOPTSTRIP is not set # CONFIG_NETFILTER_XT_MATCH_COMMENT is not set # CONFIG_NETFILTER_XT_MATCH_DCCP is not set # CONFIG_NETFILTER_XT_MATCH_DSCP is not set # CONFIG_NETFILTER_XT_MATCH_ESP is not set # CONFIG_NETFILTER_XT_MATCH_HASHLIMIT is not set # CONFIG_NETFILTER_XT_MATCH_HL is not set # CONFIG_NETFILTER_XT_MATCH_IPRANGE is not set # CONFIG_NETFILTER_XT_MATCH_LENGTH is not set # CONFIG_NETFILTER_XT_MATCH_LIMIT is not set # CONFIG_NETFILTER_XT_MATCH_MAC is not set # CONFIG_NETFILTER_XT_MATCH_MARK is not set # CONFIG_NETFILTER_XT_MATCH_MULTIPORT is not set # CONFIG_NETFILTER_XT_MATCH_OWNER is not set # CONFIG_NETFILTER_XT_MATCH_POLICY is not set # CONFIG_NETFILTER_XT_MATCH_PKTTYPE is not set # CONFIG_NETFILTER_XT_MATCH_QUOTA is not set # CONFIG_NETFILTER_XT_MATCH_RATEEST is not set # CONFIG_NETFILTER_XT_MATCH_REALM is not set # CONFIG_NETFILTER_XT_MATCH_RECENT is not set # CONFIG_NETFILTER_XT_MATCH_SCTP is not set # CONFIG_NETFILTER_XT_MATCH_STATISTIC is not set # CONFIG_NETFILTER_XT_MATCH_STRING is not set # CONFIG_NETFILTER_XT_MATCH_TCPMSS is not set # CONFIG_NETFILTER_XT_MATCH_TIME is not set # CONFIG_NETFILTER_XT_MATCH_U32 is not set # CONFIG_IP_VS is not set # # IP: Netfilter Configuration # # CONFIG_NF_DEFRAG_IPV4 is not set # CONFIG_IP_NF_QUEUE is not set CONFIG_IP_NF_IPTABLES=m # CONFIG_IP_NF_MATCH_ADDRTYPE is not set # CONFIG_IP_NF_MATCH_AH is not set # CONFIG_IP_NF_MATCH_ECN is not set # CONFIG_IP_NF_MATCH_TTL is not set CONFIG_IP_NF_FILTER=m # CONFIG_IP_NF_TARGET_REJECT is not set # CONFIG_IP_NF_TARGET_LOG is not set # CONFIG_IP_NF_TARGET_ULOG is not set CONFIG_IP_NF_MANGLE=m # CONFIG_IP_NF_TARGET_ECN is not set # CONFIG_IP_NF_TARGET_TTL is not set # CONFIG_IP_NF_RAW is not set # CONFIG_IP_NF_ARPTABLES is not set # # IPv6: Netfilter Configuration # # CONFIG_IP6_NF_QUEUE is not set # CONFIG_IP6_NF_IPTABLES is not set # CONFIG_IP_DCCP is not set # CONFIG_IP_SCTP is not set # CONFIG_TIPC is not set # CONFIG_ATM is not set # CONFIG_BRIDGE is not set # CONFIG_NET_DSA is not set # CONFIG_VLAN_8021Q is not set # CONFIG_DECNET is not set # CONFIG_LLC2 is not set # CONFIG_IPX is not set # CONFIG_ATALK is not set # CONFIG_X25 is not set # CONFIG_LAPB is not set # CONFIG_ECONET is not set # CONFIG_WAN_ROUTER is not set # CONFIG_PHONET is not set # CONFIG_NET_SCHED is not set # CONFIG_DCB is not set # # Network testing # # CONFIG_NET_PKTGEN is not set # CONFIG_HAMRADIO is not set # CONFIG_CAN is not set # CONFIG_IRDA is not set # CONFIG_BT is not set # CONFIG_AF_RXRPC is not set CONFIG_WIRELESS=y # CONFIG_CFG80211 is not set # CONFIG_WIRELESS_OLD_REGULATORY is not set # CONFIG_WIRELESS_EXT is not set # CONFIG_LIB80211 is not set # CONFIG_MAC80211 is not set # CONFIG_WIMAX is not set # CONFIG_RFKILL is not set # CONFIG_NET_9P is not set # # Device Drivers # # # Generic Driver Options # CONFIG_UEVENT_HELPER_PATH="/sbin/hotplug" CONFIG_STANDALONE=y CONFIG_PREVENT_FIRMWARE_BUILD=y CONFIG_FW_LOADER=y CONFIG_FIRMWARE_IN_KERNEL=y CONFIG_EXTRA_FIRMWARE="" # CONFIG_SYS_HYPERVISOR is not set # CONFIG_CONNECTOR is not set # CONFIG_MTD is not set CONFIG_OF_DEVICE=y CONFIG_OF_I2C=y # CONFIG_PARPORT is not set CONFIG_BLK_DEV=y # CONFIG_BLK_DEV_FD is not set # CONFIG_BLK_CPQ_DA is not set # CONFIG_BLK_CPQ_CISS_DA is not set # CONFIG_BLK_DEV_DAC960 is not set # CONFIG_BLK_DEV_UMEM is not set # CONFIG_BLK_DEV_COW_COMMON is not set CONFIG_BLK_DEV_LOOP=y # CONFIG_BLK_DEV_CRYPTOLOOP is not set # CONFIG_BLK_DEV_NBD is not set # CONFIG_BLK_DEV_SX8 is not set CONFIG_BLK_DEV_RAM=y CONFIG_BLK_DEV_RAM_COUNT=16 CONFIG_BLK_DEV_RAM_SIZE=16384 # CONFIG_BLK_DEV_XIP is not set # CONFIG_CDROM_PKTCDVD is not set # CONFIG_ATA_OVER_ETH is not set # CONFIG_XILINX_SYSACE is not set # CONFIG_XILINX_SYSACE_OLD is not set # CONFIG_BLK_DEV_HD is not set CONFIG_MISC_DEVICES=y # CONFIG_PHANTOM is not set # CONFIG_SGI_IOC4 is not set # CONFIG_TIFM_CORE is not set # CONFIG_ICS932S401 is not set # CONFIG_ENCLOSURE_SERVICES is not set # CONFIG_HP_ILO is not set # CONFIG_ISL29003 is not set # CONFIG_C2PORT is not set # # EEPROM support # # CONFIG_EEPROM_AT24 is not set # CONFIG_EEPROM_LEGACY is not set # CONFIG_EEPROM_93CX6 is not set CONFIG_XILINX_DRIVERS=y CONFIG_NEED_XILINX_LLDMA=y CONFIG_HAVE_IDE=y # CONFIG_IDE is not set # # SCSI device support # # CONFIG_RAID_ATTRS is not set # CONFIG_SCSI is not set # CONFIG_SCSI_DMA is not set # CONFIG_SCSI_NETLINK is not set # CONFIG_ATA is not set # CONFIG_MD is not set # CONFIG_FUSION is not set # # IEEE 1394 (FireWire) support # # # Enable only one of the two stacks, unless you know what you are doing # # CONFIG_FIREWIRE is not set # CONFIG_IEEE1394 is not set # CONFIG_I2O is not set # CONFIG_MACINTOSH_DRIVERS is not set CONFIG_NETDEVICES=y CONFIG_COMPAT_NET_DEV_OPS=y # CONFIG_DUMMY is not set # CONFIG_BONDING is not set # CONFIG_MACVLAN is not set # CONFIG_EQUALIZER is not set # CONFIG_TUN is not set # CONFIG_VETH is not set # CONFIG_ARCNET is not set # CONFIG_PHYLIB is not set CONFIG_NET_ETHERNET=y CONFIG_MII=y # CONFIG_HAPPYMEAL is not set # CONFIG_SUNGEM is not set # CONFIG_CASSINI is not set # CONFIG_NET_VENDOR_3COM is not set # CONFIG_ETHOC is not set # CONFIG_DNET is not set # CONFIG_NET_TULIP is not set # CONFIG_HP100 is not set # CONFIG_IBM_NEW_EMAC is not set # CONFIG_IBM_NEW_EMAC_ZMII is not set # CONFIG_IBM_NEW_EMAC_RGMII is not set # CONFIG_IBM_NEW_EMAC_TAH is not set # CONFIG_IBM_NEW_EMAC_EMAC4 is not set # CONFIG_IBM_NEW_EMAC_NO_FLOW_CTRL is not set # CONFIG_IBM_NEW_EMAC_MAL_CLR_ICINTSTAT is not set # CONFIG_IBM_NEW_EMAC_MAL_COMMON_ERR is not set # CONFIG_NET_PCI is not set # CONFIG_B44 is not set # CONFIG_XILINX_EMAC is not set # CONFIG_XILINX_EMACLITE is not set # CONFIG_ATL2 is not set CONFIG_NETDEV_1000=y # CONFIG_ACENIC is not set # CONFIG_DL2K is not set # CONFIG_E1000 is not set # CONFIG_E1000E is not set # CONFIG_IP1000 is not set # CONFIG_IGB is not set # CONFIG_IGBVF is not set # CONFIG_NS83820 is not set # CONFIG_HAMACHI is not set # CONFIG_YELLOWFIN is not set # CONFIG_R8169 is not set # CONFIG_SIS190 is not set # CONFIG_SKGE is not set # CONFIG_SKY2 is not set # CONFIG_VIA_VELOCITY is not set # CONFIG_TIGON3 is not set # CONFIG_BNX2 is not set # CONFIG_QLA3XXX is not set # CONFIG_ATL1 is not set # CONFIG_XILINX_TEMAC is not set # CONFIG_ATL1E is not set CONFIG_XILINX_LLTEMAC=y # CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_RGMII is not set CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_GMII=y # CONFIG_XILINX_LLTEMAC_MARVELL_88E1111_MII is not set # CONFIG_XILINX_LLTEMAC_NATIONAL_DP83865_GMII is not set # CONFIG_ATL1C is not set # CONFIG_JME is not set # CONFIG_NETDEV_10000 is not set # CONFIG_TR is not set # # Wireless LAN # # CONFIG_WLAN_PRE80211 is not set # CONFIG_WLAN_80211 is not set # # Enable WiMAX (Networking options) to see the WiMAX drivers # # CONFIG_WAN is not set # CONFIG_FDDI is not set # CONFIG_HIPPI is not set # CONFIG_PPP is not set # CONFIG_SLIP is not set # CONFIG_NETCONSOLE is not set # CONFIG_NETPOLL is not set # CONFIG_NET_POLL_CONTROLLER is not set # CONFIG_ISDN is not set # CONFIG_PHONE is not set # # Input device support # CONFIG_INPUT=y # CONFIG_INPUT_FF_MEMLESS is not set # CONFIG_INPUT_POLLDEV is not set # # Userland interfaces # CONFIG_INPUT_MOUSEDEV=y CONFIG_INPUT_MOUSEDEV_PSAUX=y CONFIG_INPUT_MOUSEDEV_SCREEN_X=1024 CONFIG_INPUT_MOUSEDEV_SCREEN_Y=768 # CONFIG_INPUT_JOYDEV is not set # CONFIG_INPUT_EVDEV is not set # CONFIG_INPUT_EVBUG is not set # # Input Device Drivers # CONFIG_INPUT_KEYBOARD=y CONFIG_KEYBOARD_ATKBD=y # CONFIG_KEYBOARD_SUNKBD is not set # CONFIG_KEYBOARD_LKKBD is not set # CONFIG_KEYBOARD_XTKBD is not set # CONFIG_KEYBOARD_NEWTON is not set # CONFIG_KEYBOARD_STOWAWAY is not set CONFIG_INPUT_MOUSE=y CONFIG_MOUSE_PS2=y CONFIG_MOUSE_PS2_ALPS=y CONFIG_MOUSE_PS2_LOGIPS2PP=y CONFIG_MOUSE_PS2_SYNAPTICS=y CONFIG_MOUSE_PS2_TRACKPOINT=y # CONFIG_MOUSE_PS2_ELANTECH is not set # CONFIG_MOUSE_PS2_TOUCHKIT is not set # CONFIG_MOUSE_SERIAL is not set # CONFIG_MOUSE_VSXXXAA is not set # CONFIG_INPUT_JOYSTICK is not set # CONFIG_INPUT_TABLET is not set # CONFIG_INPUT_TOUCHSCREEN is not set # CONFIG_INPUT_MISC is not set # # Hardware I/O ports # CONFIG_SERIO=y # CONFIG_SERIO_I8042 is not set CONFIG_SERIO_SERPORT=y # CONFIG_SERIO_PCIPS2 is not set CONFIG_SERIO_LIBPS2=y # CONFIG_SERIO_XILINXPS2 is not set # CONFIG_SERIO_XILINX_XPS_PS2 is not set # CONFIG_SERIO_RAW is not set # CONFIG_GAMEPORT is not set # # Character devices # CONFIG_VT=y CONFIG_CONSOLE_TRANSLATIONS=y CONFIG_VT_CONSOLE=y CONFIG_HW_CONSOLE=y # CONFIG_VT_HW_CONSOLE_BINDING is not set CONFIG_DEVKMEM=y # CONFIG_SERIAL_NONSTANDARD is not set # CONFIG_NOZOMI is not set # # Serial drivers # CONFIG_SERIAL_8250=y CONFIG_SERIAL_8250_CONSOLE=y CONFIG_SERIAL_8250_PCI=y CONFIG_SERIAL_8250_NR_UARTS=4 CONFIG_SERIAL_8250_RUNTIME_UARTS=4 # CONFIG_SERIAL_8250_EXTENDED is not set # # Non-8250 serial port support # CONFIG_SERIAL_UARTLITE=y CONFIG_SERIAL_UARTLITE_CONSOLE=y CONFIG_SERIAL_CORE=y CONFIG_SERIAL_CORE_CONSOLE=y # CONFIG_SERIAL_JSM is not set CONFIG_SERIAL_OF_PLATFORM=y # CONFIG_SERIAL_OF_PLATFORM_NWPSERIAL is not set CONFIG_UNIX98_PTYS=y # CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set CONFIG_LEGACY_PTYS=y CONFIG_LEGACY_PTY_COUNT=256 # CONFIG_HVC_UDBG is not set # CONFIG_IPMI_HANDLER is not set CONFIG_HW_RANDOM=m # CONFIG_HW_RANDOM_TIMERIOMEM is not set # CONFIG_NVRAM is not set # CONFIG_GEN_RTC is not set CONFIG_XILINX_HWICAP=y # CONFIG_R3964 is not set # CONFIG_APPLICOM is not set # CONFIG_RAW_DRIVER is not set # CONFIG_TCG_TPM is not set CONFIG_DEVPORT=y CONFIG_I2C=y CONFIG_I2C_BOARDINFO=y CONFIG_I2C_CHARDEV=y CONFIG_I2C_HELPER_AUTO=y # # I2C Hardware Bus support # # # PC SMBus host controller drivers # # CONFIG_I2C_ALI1535 is not set # CONFIG_I2C_ALI1563 is not set # CONFIG_I2C_ALI15X3 is not set # CONFIG_I2C_AMD756 is not set # CONFIG_I2C_AMD8111 is not set # CONFIG_I2C_I801 is not set # CONFIG_I2C_ISCH is not set # CONFIG_I2C_PIIX4 is not set # CONFIG_I2C_NFORCE2 is not set # CONFIG_I2C_SIS5595 is not set # CONFIG_I2C_SIS630 is not set # CONFIG_I2C_SIS96X is not set # CONFIG_I2C_VIA is not set # CONFIG_I2C_VIAPRO is not set # # I2C system bus drivers (mostly embedded / system-on-chip) # # CONFIG_I2C_IBM_IIC is not set # CONFIG_I2C_MPC is not set # CONFIG_I2C_OCORES is not set # CONFIG_I2C_SIMTEC is not set # # External I2C/SMBus adapter drivers # # CONFIG_I2C_PARPORT_LIGHT is not set # CONFIG_I2C_TAOS_EVM is not set # # Graphics adapter I2C/DDC channel drivers # # CONFIG_I2C_VOODOO3 is not set # # Other I2C/SMBus bus drivers # # CONFIG_I2C_PCA_PLATFORM is not set # CONFIG_I2C_STUB is not set # # Miscellaneous I2C Chip support # # CONFIG_DS1682 is not set # CONFIG_SENSORS_PCF8574 is not set # CONFIG_PCF8575 is not set # CONFIG_SENSORS_PCA9539 is not set # CONFIG_SENSORS_MAX6875 is not set # CONFIG_SENSORS_TSL2550 is not set CONFIG_I2C_DEBUG_CORE=y CONFIG_I2C_DEBUG_ALGO=y # CONFIG_I2C_DEBUG_BUS is not set # CONFIG_I2C_DEBUG_CHIP is not set # CONFIG_SPI is not set CONFIG_ARCH_WANT_OPTIONAL_GPIOLIB=y # CONFIG_GPIOLIB is not set # CONFIG_W1 is not set # CONFIG_POWER_SUPPLY is not set # CONFIG_HWMON is not set # CONFIG_THERMAL is not set # CONFIG_THERMAL_HWMON is not set # CONFIG_WATCHDOG is not set CONFIG_SSB_POSSIBLE=y # # Sonics Silicon Backplane # # CONFIG_SSB is not set # # Multifunction device drivers # # CONFIG_MFD_CORE is not set # CONFIG_MFD_SM501 is not set # CONFIG_HTC_PASIC3 is not set # CONFIG_TWL4030_CORE is not set # CONFIG_MFD_TMIO is not set # CONFIG_PMIC_DA903X is not set # CONFIG_MFD_WM8400 is not set # CONFIG_MFD_WM8350_I2C is not set # CONFIG_MFD_PCF50633 is not set # CONFIG_REGULATOR is not set # # Multimedia devices # # # Multimedia core support # # CONFIG_VIDEO_DEV is not set # CONFIG_DVB_CORE is not set # CONFIG_VIDEO_MEDIA is not set # # Multimedia drivers # # CONFIG_DAB is not set # # Graphics support # # CONFIG_AGP is not set # CONFIG_DRM is not set # CONFIG_VGASTATE is not set # CONFIG_VIDEO_OUTPUT_CONTROL is not set CONFIG_FB=y # CONFIG_FIRMWARE_EDID is not set # CONFIG_FB_DDC is not set # CONFIG_FB_BOOT_VESA_SUPPORT is not set CONFIG_FB_CFB_FILLRECT=y CONFIG_FB_CFB_COPYAREA=y CONFIG_FB_CFB_IMAGEBLIT=y # CONFIG_FB_CFB_REV_PIXELS_IN_BYTE is not set # CONFIG_FB_SYS_FILLRECT is not set # CONFIG_FB_SYS_COPYAREA is not set # CONFIG_FB_SYS_IMAGEBLIT is not set # CONFIG_FB_FOREIGN_ENDIAN is not set # CONFIG_FB_SYS_FOPS is not set # CONFIG_FB_SVGALIB is not set # CONFIG_FB_MACMODES is not set # CONFIG_FB_BACKLIGHT is not set # CONFIG_FB_MODE_HELPERS is not set # CONFIG_FB_TILEBLITTING is not set # # Frame buffer hardware drivers # # CONFIG_FB_CIRRUS is not set # CONFIG_FB_PM2 is not set # CONFIG_FB_CYBER2000 is not set # CONFIG_FB_OF is not set # CONFIG_FB_CT65550 is not set # CONFIG_FB_ASILIANT is not set # CONFIG_FB_IMSTT is not set # CONFIG_FB_VGA16 is not set # CONFIG_FB_S1D13XXX is not set # CONFIG_FB_NVIDIA is not set # CONFIG_FB_RIVA is not set # CONFIG_FB_MATROX is not set # CONFIG_FB_RADEON is not set # CONFIG_FB_ATY128 is not set # CONFIG_FB_ATY is not set # CONFIG_FB_S3 is not set # CONFIG_FB_SAVAGE is not set # CONFIG_FB_SIS is not set # CONFIG_FB_VIA is not set # CONFIG_FB_NEOMAGIC is not set # CONFIG_FB_KYRO is not set # CONFIG_FB_3DFX is not set # CONFIG_FB_VOODOO1 is not set # CONFIG_FB_VT8623 is not set # CONFIG_FB_TRIDENT is not set # CONFIG_FB_ARK is not set # CONFIG_FB_PM3 is not set # CONFIG_FB_CARMINE is not set # CONFIG_FB_IBM_GXT4500 is not set CONFIG_FB_XILINX=y # CONFIG_FB_VIRTUAL is not set # CONFIG_FB_METRONOME is not set # CONFIG_FB_MB862XX is not set # CONFIG_FB_BROADSHEET is not set # CONFIG_BACKLIGHT_LCD_SUPPORT is not set # # Display device support # # CONFIG_DISPLAY_SUPPORT is not set # # Console display driver support # CONFIG_DUMMY_CONSOLE=y CONFIG_FRAMEBUFFER_CONSOLE=y # CONFIG_FRAMEBUFFER_CONSOLE_DETECT_PRIMARY is not set # CONFIG_FRAMEBUFFER_CONSOLE_ROTATION is not set CONFIG_FONTS=y CONFIG_FONT_8x8=y CONFIG_FONT_8x16=y # CONFIG_FONT_6x11 is not set # CONFIG_FONT_7x14 is not set # CONFIG_FONT_PEARL_8x8 is not set # CONFIG_FONT_ACORN_8x8 is not set # CONFIG_FONT_MINI_4x6 is not set # CONFIG_FONT_SUN8x16 is not set # CONFIG_FONT_SUN12x22 is not set # CONFIG_FONT_10x18 is not set CONFIG_LOGO=y CONFIG_LOGO_LINUX_MONO=y CONFIG_LOGO_LINUX_VGA16=y CONFIG_LOGO_LINUX_CLUT224=y # CONFIG_SOUND is not set # CONFIG_HID_SUPPORT is not set # CONFIG_USB_SUPPORT is not set # CONFIG_UWB is not set # CONFIG_MMC is not set # CONFIG_MEMSTICK is not set # CONFIG_NEW_LEDS is not set # CONFIG_ACCESSIBILITY is not set # CONFIG_INFINIBAND is not set # CONFIG_EDAC is not set # CONFIG_RTC_CLASS is not set # CONFIG_DMADEVICES is not set # CONFIG_AUXDISPLAY is not set CONFIG_XILINX_EDK=y # CONFIG_XILINX_LLDMA_USE_DCR is not set # CONFIG_UIO is not set # CONFIG_STAGING is not set # # File systems # CONFIG_EXT2_FS=y # CONFIG_EXT2_FS_XATTR is not set # CONFIG_EXT2_FS_XIP is not set # CONFIG_EXT3_FS is not set # CONFIG_EXT4_FS is not set # CONFIG_REISERFS_FS is not set # CONFIG_JFS_FS is not set # CONFIG_FS_POSIX_ACL is not set CONFIG_FILE_LOCKING=y # CONFIG_XFS_FS is not set # CONFIG_OCFS2_FS is not set # CONFIG_BTRFS_FS is not set CONFIG_DNOTIFY=y CONFIG_INOTIFY=y CONFIG_INOTIFY_USER=y # CONFIG_QUOTA is not set CONFIG_AUTOFS_FS=y CONFIG_AUTOFS4_FS=y CONFIG_FUSE_FS=m # # Caches # # CONFIG_FSCACHE is not set # # CD-ROM/DVD Filesystems # # CONFIG_ISO9660_FS is not set # CONFIG_UDF_FS is not set # # DOS/FAT/NT Filesystems # CONFIG_FAT_FS=y CONFIG_MSDOS_FS=y CONFIG_VFAT_FS=y CONFIG_FAT_DEFAULT_CODEPAGE=437 CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1" # CONFIG_NTFS_FS is not set # # Pseudo filesystems # CONFIG_PROC_FS=y # CONFIG_PROC_KCORE is not set CONFIG_PROC_SYSCTL=y CONFIG_PROC_PAGE_MONITOR=y CONFIG_SYSFS=y CONFIG_TMPFS=y # CONFIG_TMPFS_POSIX_ACL is not set # CONFIG_HUGETLB_PAGE is not set # CONFIG_CONFIGFS_FS is not set CONFIG_MISC_FILESYSTEMS=y # CONFIG_ADFS_FS is not set # CONFIG_AFFS_FS is not set # CONFIG_HFS_FS is not set # CONFIG_HFSPLUS_FS is not set # CONFIG_BEFS_FS is not set # CONFIG_BFS_FS is not set # CONFIG_EFS_FS is not set CONFIG_CRAMFS=y # CONFIG_SQUASHFS is not set # CONFIG_VXFS_FS is not set # CONFIG_MINIX_FS is not set # CONFIG_OMFS_FS is not set # CONFIG_HPFS_FS is not set # CONFIG_QNX4FS_FS is not set CONFIG_ROMFS_FS=y CONFIG_ROMFS_BACKED_BY_BLOCK=y # CONFIG_ROMFS_BACKED_BY_MTD is not set # CONFIG_ROMFS_BACKED_BY_BOTH is not set CONFIG_ROMFS_ON_BLOCK=y # CONFIG_SYSV_FS is not set # CONFIG_UFS_FS is not set # CONFIG_NILFS2_FS is not set CONFIG_NETWORK_FILESYSTEMS=y CONFIG_NFS_FS=y CONFIG_NFS_V3=y # CONFIG_NFS_V3_ACL is not set # CONFIG_NFS_V4 is not set CONFIG_ROOT_NFS=y CONFIG_NFSD=y CONFIG_NFSD_V3=y # CONFIG_NFSD_V3_ACL is not set # CONFIG_NFSD_V4 is not set CONFIG_LOCKD=y CONFIG_LOCKD_V4=y CONFIG_EXPORTFS=y CONFIG_NFS_COMMON=y CONFIG_SUNRPC=y # CONFIG_RPCSEC_GSS_KRB5 is not set # CONFIG_RPCSEC_GSS_SPKM3 is not set CONFIG_SMB_FS=y # CONFIG_SMB_NLS_DEFAULT is not set # CONFIG_CIFS is not set # CONFIG_NCP_FS is not set # CONFIG_CODA_FS is not set # CONFIG_AFS_FS is not set # # Partition Types # # CONFIG_PARTITION_ADVANCED is not set CONFIG_MSDOS_PARTITION=y CONFIG_NLS=y CONFIG_NLS_DEFAULT="iso8859-1" CONFIG_NLS_CODEPAGE_437=y # CONFIG_NLS_CODEPAGE_737 is not set # CONFIG_NLS_CODEPAGE_775 is not set # CONFIG_NLS_CODEPAGE_850 is not set # CONFIG_NLS_CODEPAGE_852 is not set # CONFIG_NLS_CODEPAGE_855 is not set # CONFIG_NLS_CODEPAGE_857 is not set # CONFIG_NLS_CODEPAGE_860 is not set # CONFIG_NLS_CODEPAGE_861 is not set # CONFIG_NLS_CODEPAGE_862 is not set # CONFIG_NLS_CODEPAGE_863 is not set # CONFIG_NLS_CODEPAGE_864 is not set # CONFIG_NLS_CODEPAGE_865 is not set # CONFIG_NLS_CODEPAGE_866 is not set # CONFIG_NLS_CODEPAGE_869 is not set # CONFIG_NLS_CODEPAGE_936 is not set # CONFIG_NLS_CODEPAGE_950 is not set # CONFIG_NLS_CODEPAGE_932 is not set # CONFIG_NLS_CODEPAGE_949 is not set # CONFIG_NLS_CODEPAGE_874 is not set # CONFIG_NLS_ISO8859_8 is not set # CONFIG_NLS_CODEPAGE_1250 is not set # CONFIG_NLS_CODEPAGE_1251 is not set CONFIG_NLS_ASCII=m CONFIG_NLS_ISO8859_1=m # CONFIG_NLS_ISO8859_2 is not set # CONFIG_NLS_ISO8859_3 is not set # CONFIG_NLS_ISO8859_4 is not set # CONFIG_NLS_ISO8859_5 is not set # CONFIG_NLS_ISO8859_6 is not set # CONFIG_NLS_ISO8859_7 is not set # CONFIG_NLS_ISO8859_9 is not set # CONFIG_NLS_ISO8859_13 is not set # CONFIG_NLS_ISO8859_14 is not set # CONFIG_NLS_ISO8859_15 is not set # CONFIG_NLS_KOI8_R is not set # CONFIG_NLS_KOI8_U is not set CONFIG_NLS_UTF8=m # CONFIG_DLM is not set # CONFIG_BINARY_PRINTF is not set # # Library routines # CONFIG_BITREVERSE=y CONFIG_GENERIC_FIND_LAST_BIT=y CONFIG_CRC_CCITT=y # CONFIG_CRC16 is not set # CONFIG_CRC_T10DIF is not set # CONFIG_CRC_ITU_T is not set CONFIG_CRC32=y # CONFIG_CRC7 is not set # CONFIG_LIBCRC32C is not set CONFIG_ZLIB_INFLATE=y CONFIG_DECOMPRESS_GZIP=y CONFIG_DECOMPRESS_BZIP2=y CONFIG_DECOMPRESS_LZMA=y CONFIG_HAS_IOMEM=y CONFIG_HAS_IOPORT=y CONFIG_HAS_DMA=y CONFIG_HAVE_LMB=y CONFIG_NLATTR=y # # Kernel hacking # # CONFIG_PRINTK_TIME is not set CONFIG_ENABLE_WARN_DEPRECATED=y CONFIG_ENABLE_MUST_CHECK=y CONFIG_FRAME_WARN=1024 # CONFIG_MAGIC_SYSRQ is not set # CONFIG_UNUSED_SYMBOLS is not set # CONFIG_DEBUG_FS is not set # CONFIG_HEADERS_CHECK is not set # CONFIG_DEBUG_KERNEL is not set CONFIG_DEBUG_BUGVERBOSE=y CONFIG_DEBUG_MEMORY_INIT=y # CONFIG_RCU_CPU_STALL_DETECTOR is not set # CONFIG_LATENCYTOP is not set CONFIG_SYSCTL_SYSCALL_CHECK=y CONFIG_HAVE_FUNCTION_TRACER=y CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y CONFIG_HAVE_DYNAMIC_FTRACE=y CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y CONFIG_TRACING_SUPPORT=y # # Tracers # # CONFIG_FUNCTION_TRACER is not set # CONFIG_PREEMPT_TRACER is not set # CONFIG_SCHED_TRACER is not set # CONFIG_CONTEXT_SWITCH_TRACER is not set # CONFIG_EVENT_TRACER is not set # CONFIG_BOOT_TRACER is not set # CONFIG_TRACE_BRANCH_PROFILING is not set # CONFIG_STACK_TRACER is not set # CONFIG_KMEMTRACE is not set # CONFIG_WORKQUEUE_TRACER is not set # CONFIG_BLK_DEV_IO_TRACE is not set # CONFIG_SAMPLES is not set CONFIG_HAVE_ARCH_KGDB=y CONFIG_PRINT_STACK_DEPTH=64 # CONFIG_IRQSTACKS is not set # CONFIG_PPC_EARLY_DEBUG is not set # # Security options # # CONFIG_KEYS is not set # CONFIG_SECURITY is not set # CONFIG_SECURITYFS is not set # CONFIG_SECURITY_FILE_CAPABILITIES is not set CONFIG_CRYPTO=y # # Crypto core or helper # # CONFIG_CRYPTO_FIPS is not set # CONFIG_CRYPTO_MANAGER is not set # CONFIG_CRYPTO_MANAGER2 is not set # CONFIG_CRYPTO_GF128MUL is not set # CONFIG_CRYPTO_NULL is not set # CONFIG_CRYPTO_CRYPTD is not set # CONFIG_CRYPTO_AUTHENC is not set # CONFIG_CRYPTO_TEST is not set # # Authenticated Encryption with Associated Data # # CONFIG_CRYPTO_CCM is not set # CONFIG_CRYPTO_GCM is not set # CONFIG_CRYPTO_SEQIV is not set # # Block modes # # CONFIG_CRYPTO_CBC is not set # CONFIG_CRYPTO_CTR is not set # CONFIG_CRYPTO_CTS is not set # CONFIG_CRYPTO_ECB is not set # CONFIG_CRYPTO_LRW is not set # CONFIG_CRYPTO_PCBC is not set # CONFIG_CRYPTO_XTS is not set # # Hash modes # # CONFIG_CRYPTO_HMAC is not set # CONFIG_CRYPTO_XCBC is not set # # Digest # # CONFIG_CRYPTO_CRC32C is not set # CONFIG_CRYPTO_MD4 is not set # CONFIG_CRYPTO_MD5 is not set # CONFIG_CRYPTO_MICHAEL_MIC is not set # CONFIG_CRYPTO_RMD128 is not set # CONFIG_CRYPTO_RMD160 is not set # CONFIG_CRYPTO_RMD256 is not set # CONFIG_CRYPTO_RMD320 is not set # CONFIG_CRYPTO_SHA1 is not set # CONFIG_CRYPTO_SHA256 is not set # CONFIG_CRYPTO_SHA512 is not set # CONFIG_CRYPTO_TGR192 is not set # CONFIG_CRYPTO_WP512 is not set # # Ciphers # # CONFIG_CRYPTO_AES is not set # CONFIG_CRYPTO_ANUBIS is not set # CONFIG_CRYPTO_ARC4 is not set # CONFIG_CRYPTO_BLOWFISH is not set # CONFIG_CRYPTO_CAMELLIA is not set # CONFIG_CRYPTO_CAST5 is not set # CONFIG_CRYPTO_CAST6 is not set # CONFIG_CRYPTO_DES is not set # CONFIG_CRYPTO_FCRYPT is not set # CONFIG_CRYPTO_KHAZAD is not set # CONFIG_CRYPTO_SALSA20 is not set # CONFIG_CRYPTO_SEED is not set # CONFIG_CRYPTO_SERPENT is not set # CONFIG_CRYPTO_TEA is not set # CONFIG_CRYPTO_TWOFISH is not set # # Compression # # CONFIG_CRYPTO_DEFLATE is not set # CONFIG_CRYPTO_ZLIB is not set # CONFIG_CRYPTO_LZO is not set # # Random Number Generation # # CONFIG_CRYPTO_ANSI_CPRNG is not set CONFIG_CRYPTO_HW=y # CONFIG_CRYPTO_DEV_HIFN_795X is not set # CONFIG_CRYPTO_DEV_PPC4XX is not set # CONFIG_PPC_CLOCK is not set # CONFIG_VIRTUALIZATION is not set
The message is showing below:
Linux/PowerPC load: console=ttyUL0 root=/dev/ram Finalizing device tree... flat tree at 0x720300 Using Xilinx Virtex machine description Linux version 2.6.30 (yixuan@localhost) (gcc version 4.2.2) #5 PREEMPT Wed Sep 1 6 12:41:53 BST 2009 Found initrd at 0xc059e000:0xc07121cb Zone PFN ranges: DMA 0x00000000 -> 0x00030000 Normal 0x00030000 -> 0x00030000 Movable zone start PFN for each node early_node_map[1] active PFN ranges 0: 0x00000000 -> 0x00030000 MMU: Allocated 1088 bytes of context maps for 255 contexts Built 1 zonelists in Zone order, mobility grouping on. Total pages: 195072 Kernel command line: console=ttyUL0 root=/dev/ram NR_IRQS:512 Xilinx intc at 0x81800000 mapped to 0xfddff000 PID hash table entries: 4096 (order: 12, 16384 bytes) clocksource: timebase mult[d55555] shift[22] registered Console: colour dummy device 80x25 console [ttyUL0] enabled Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) Memory: 774016k/786432k available (3264k kernel code, 12020k reserved, 136k data , 133k bss, 160k init) Kernel virtual memory layout: * 0xffffe000..0xfffff000 : fixmap * 0xfde00000..0xfe000000 : consistent mem * 0xfddfe000..0xfde00000 : early ioremap * 0xf1000000..0xfddfe000 : vmalloc & ioremap Calibrating delay loop... 598.01 BogoMIPS (lpj=1196032) Mount-cache hash table entries: 512 Oops: Exception in kernel mode, sig: 4 [#1] PREEMPT Xilinx Virtex Modules linked in: **bleep**: ef825f90 LR: ef825fc0 CTR: c002f574 REGS: c002c67c TRAP: 0700 Not tainted (2.6.30) MSR: 0002ad10 <EE,FP,CE,DR> CR: 00029030 XER: e0000030 TASK = ef821490[2] 'kthreadd' THREAD: ef824000 GPR00: 00000000 c002c72c ef821490 00000003 ef825fc0 00029030 00000003 ef825f90 GPR08: c027ad98 00000000 00000000 00000000 ef824000 ffffffff ffffffff ffffffff GPR16: ffffffff c0028744 c02c7930 00021030 c0330000 c0360000 c0330000 c035a048 GPR24: 00000001 ef821490 c004b9ec c0335720 c033572c ef823f0c c004b9ec ef823ee8 **bleep** [ef825f90] 0xef825f90 LR [ef825fc0] 0xef825fc0 Call Trace: Instruction dump: XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX ---[ end trace 31fd0ba7d8756001 ]--- note: kthreadd[2] exited with preempt_count 29 Oops: Exception in kernel mode, sig: 4 [#2] PREEMPT Xilinx Virtex Modules linked in: **bleep**: c002c6dc LR: c002c72c CTR: c002f574 REGS: c002c3cc TRAP: 0700 Tainted: G D (2.6.30) MSR: 00021030 <ME,CE,IR,DR> CR: 95025093 XER: c0000030 TASK = ef821490[2] 'kthreadd' THREAD: ef824000 GPR00: ef8210b8 c002c47c ef821490 c0333c18 ef8210b0 00000000 0041beb7 00000000 GPR08: 0041beb7 ef8210b8 00000000 00000000 0041beb7 ffffffff ffffffff ffffffff GPR16: ffffffff c0028744 c02c7930 c028441c 00000000 000f4240 ef821618 ef821508 GPR24: c0330000 000f4240 ef821618 c002c000 c0333be8 c0333c18 c0333c18 ef8210b8 **bleep** [c002c6dc] __dequeue_entity+0x48/0x70 LR [c002c72c] set_next_entity+0x28/0x60 Call Trace: Instruction dump: ef824000 ffffffff ffffffff ffffffff ffffffff c0028744 c02c7930 00021030 c0330000 c0360000 c0330000 c035a048 <00000001> ef821490 c004b9ec c0335720 Kernel panic - not syncing: Fatal exception in interrupt Call Trace: Rebooting in 180 seconds..
Looks like it is the interrupt problem. I pasted my memory map info:
(0b0100000000-0b0111111111) ppc405_0 (0000000000-0x3fffffff) DDR2_SDRAM ppc405_0_dplb1 (0000000000-0x3fffffff) DDR2_SDRAM ppc405_0_iplb1 (0x60a00000-0x60a03fff) ppc405_0_docm_cntlr ppc405_0_docm (0x81400000-0x8140ffff) LEDs_8Bit plb (0x81800000-0x8180ffff) xps_intc_0 plb (0x84000000-0x8400ffff) RS232_Uart_1 plb (0xc1ff8000-0xc1ffbfff) ppc405_0_iocm_cntlr ppc405_0_iocm (0xfffe0000-0xffffffff) xps_bram_if_cntlr_1 plb
The interrupt controller only has two clients: one is the LED, the other is the RS232. But the error message --- "Xilinx intc at 0x81800000 mapped to 0xfddff000" shows 0xfddff000 which is not in my memory map.
 Could you please help me on this issue? Many thanks.
Simon
Message Edited by essexer on 09-16-2009 07:19 AM
Message Edited by essexer on 09-16-2009 07:33 AM
If I use initramfs rather than ramdisk,
1. Should I use "make simpleImage.virtex405-ml405" instead of "make simpleImage.initrd.virtex405-ml405" to build the kernel?
2. Should I still use "root=/dev/ram" in the kernel command line (EDK software platform setup window)?
3. Should I delete /linuxrc according to http://www.linuxfordevices.com/c/a/Linux-For-Devices-Articles/Introducing-initramfs-a-new-model-for-initial-RAM-disks/ ?
Simon
To some extent, you're on your own here.  I have used it with Powerpc just once to make sure it worked. I use it on Microblaze.
yes to #1 I believe
yes to #2, but I don't think you have to specifiy anything for the root, but it doesn't hurt I think, it works on MicroBlaze without any root=.....
yes to #3, you HAVE to have the init link in the root dir to the init executable (like busybox)
good luck.
It works! Thank you very much.
Here is the summary of what I did for using initramfs in case anybody else needs do the same:
1. download the ramdisk.image.gz from the wiki, run as root
gunzip ramdisk.image.gz
mkdir /mnt/new-disk
mount -o loop ramdisk.image /mnt/new-disk
mkdir /root/initramfs
cd /mnt/new-disk
cp -rf * /root/initramfs/
cd /root/initramfs/
ln -sf ../bin/busybox init
rm linuxrc
cd yyyyy/linux-2.6-xlnx
sudo make menuconfig
 2. In kernel configuration,
General setup  --->
(/root/initramfs) Initramfs source file(s)
 3. Then run
sudo make simpleImage.virtex405-ml405
 4. In XMD, run
dow path/to/simpleImage.virtex405-ml405.elf
 if you have the following error:
zImage starting: loaded at 0x00400000 (sp: 0x00767efc)
Allocating 0x4a528c bytes for kernel ...
Insufficient memory for kernel at address 0! (_start=00400000, uncompressed size=0042c1f0)
Open arch/powerpc/boot/wrapper, search "simpleboot-virtex405-*)", add link_address='0x800000' below line "binary=y", then rebuild the kernel.
When you put more your own stuff in initramfs (in this case /root/initramfs),  link_address 0x800000 becomes insufficient as well (The whole kernel plus my test application is about 8MB). You can set according to your own situation. I set it to boot from 258MB ('link_address=0x10000000'), but the booting froze at
It works until I decrease the link_address to 10MB (0xa00000).  I recon it's because of my memory problem, any other comments?
PS: if you are using virtex5, change accordingly.
Simon
Message Edited by essexer on 10-01-2009 05:53 PM
Message Edited by essexer on 10-01-2009 06:56 PM
The problem with having a vmlinux / zImage too large and/or setting link_address too high is that early stages of Linux only map the first 16 MB of RAM into the TLB.  If you exceed this, then Linux is unable to access that data.  Here is one idea that I haven't tested and have no idea what the consequences are, but maybe it might work to give access to the first 128 MB of RAM:
diff --git a/arch/powerpc/kernel/head_40x.S b/arch/powerpc/kernel/head_40x.S
index a90625f..3e269d8 100644
--- a/arch/powerpc/kernel/head_40x.S
+++ b/arch/powerpc/kernel/head_40x.S
@@ -939,6 +939,48 @@ initial_mmu:
  tlbwe r4,r0,TLB_DATA    /* Load the data portion of the entry */
  tlbwe r3,r0,TLB_TAG   /* Load the tag portion of the entry */
+ addis r4,r4,0x1000000@h /* Add 16M to physical address */
+ addis r3,r3,0x1000000@h /* Add 16M to virtual address */
+ li      r0,62                    /* TLB slot 62 */
+ tlbwe r4,r0,TLB_DATA    /* Load the data portion of the entry */
+ tlbwe r3,r0,TLB_TAG   /* Load the tag portion of the entry */
+ addis r4,r4,0x1000000@h /* Add another 16M to physical address */
+ addis r3,r3,0x1000000@h /* Add another 16M to virtual address */
+ li      r0,61                    /* TLB slot 61 */
+ li      r0,60                    /* TLB slot 60 */
+ li      r0,59                    /* TLB slot 59 */
+ li      r0,58                    /* TLB slot 58 */
+ li      r0,57                    /* TLB slot 57 */
+ li      r0,56                    /* TLB slot 56 */
 #if defined(CONFIG_SERIAL_TEXT_DEBUG) && defined(SERIAL_DEBUG_IO_BASE)
  /* Load a TLB entry for the UART, so that ppc4xx_progress() can use
