essexer
Kernel panic - not syncing: kernel stack overflow
Hi, all,
When I boot the linux kernel, I had the following error. I totally lost, and don't know if there is anything I can modify to my configuration.
zImage starting: loaded at 0x00800000 (sp: 0x00b11eb0) Allocating 0x37bd64 bytes for kernel ... gunzipping (0x00000000 <- 0x0080c000:0x0099e149)...done 0x359fc4 bytes Attached initrd image at 0x0099f000-0x00b10bd0 initrd head: 0x1f8b0808 Linux/PowerPC load: console=ttyUL0 root=/dev/ram Finalizing device tree... flat tree at 0xb1e300 Using Xilinx Virtex machine description Linux version 2.6.30 (yixuan@localhost) (gcc version 4.2.2) #10 PREEMPT Sun Sep 20 03:30:43 BST 2009 Found initrd at 0xc099f000:0xc0b10bd0 Zone PFN ranges: DMA 0x00000000 -> 0x00030000 Normal 0x00030000 -> 0x00030000 Movable zone start PFN for each node early_node_map[1] active PFN ranges 0: 0x00000000 -> 0x00030000 MMU: Allocated 1088 bytes of context maps for 255 contexts Built 1 zonelists in Zone order, mobility grouping on. Total pages: 195072 Kernel command line: console=ttyUL0 root=/dev/ram NR_IRQS:512 Xilinx intc at 0x81800000 mapped to 0xfddff000 PID hash table entries: 4096 (order: 12, 16384 bytes) clocksource: timebase mult[d55555] shift[22] registered Console: colour dummy device 80x25 console [ttyUL0] enabled Dentry cache hash table entries: 131072 (order: 7, 524288 bytes) Inode-cache hash table entries: 65536 (order: 6, 262144 bytes) Memory: 774144k/786432k available (3272k kernel code, 12016k reserved, 136k data , 135k bss, 164k init) Kernel virtual memory layout: * 0xffffe000..0xfffff000 : fixmap * 0xfde00000..0xfe000000 : consistent mem * 0xfddfe000..0xfde00000 : early ioremap * 0xf1000000..0xfddfe000 : vmalloc & ioremap Calibrating delay loop... 598.01 BogoMIPS (lpj=1196032) Mount-cache hash table entries: 512 Kernel stack overflow in process ef821490, r1=c002cb1c **bleep**: ef825f90 LR: ef825fc0 CTR: ef821490 REGS: ef825f00 TRAP: ef825fc0 Not tainted (2.6.30) MSR: c027c048 <EE,PR,CE> CR: 00029030 XER: c002f220 TASK = ef821490[2] 'kthreadd' THREAD: ef824000 GPR00: ef825f10 c002cb1c ef821490 ef8218d0 ef825f30 c0007690 ef821490 ef824000 GPR08: c0335be8 c0334318 ef821490 ef8218a0 ef825f70 c027bdd4 00000000 00021030 GPR16: 10624dd3 00044b83 00000001 c035a048 000000d5 0099f000 00000000 c035b538 GPR24: 00000078 fffffffb c0335be8 ef824000 ef825f80 c027bf68 c0335be8 ef824000 **bleep** [ef825f90] 0xef825f90 LR [ef825fc0] 0xef825fc0 Call Trace: Kernel panic - not syncing: kernel stack overflow Call Trace: Rebooting in 180 seconds..
Can anybody give some suggestion?
Simon
linnj
It seems like this is the same as "Kernel panic - not syncing: Fatal exception in interrupt" thread, is it?
If it is, did you get anywhere with the other recommendations?
-- John
essexer
Hi, John,
Sorry for the late reply, I was not in the office for the last week.
It was similar with the other thread. In the previous one, this error was only shown once, then never reproduced.
I did all your suggestions, but with no luck. Any more suggestion please?
Simon
linnj
It makes it difficult to help when you start a new thread and I have to go back to the old thread for the informationa about what has been done in the past.
I'm going back to the old thread to continue.
-- John
essexer
Sorry. I thought that's two different errors. You can delete this one if you prefer.
Simon
