Linux Application Running but not getting Desired Output
I am following ug1165 to flow leds using custom IP core, previously I was not able to run the linux application now I cross compiled it successfully and Linux App is running but when I press 1 or 0 then I get "Kernel Print" kind of thing instead of blinking Leds.
note: FPGA program loading is also successful.
Re: Linux Application Running but not getting Desired Output
I'm not sure if I understand what question you are asking here. Can you provide some additional information on what you are looking to do?
I am trying to glow PL side LEDs using linux application which is explained in UG1165, I completed all the steps and even that linux application is running as you can see in Screen shot I sent, but it gets terminated when I select 1 or 0, it prints Kernel Print : set ( when 1 is pressed ) Kernel print : reset (when I select 0 ).
My problem is that I am unable to debug it and trace issue and where the thing is going wrong. What needs to be corrected? Where should I look into?
note: I have implemented chapter-9 "Custom IP and Device Driver for Linux " and I am using my own created block design in vivado 2016.3 as per instruction given in the ug1165 but I am using those files which is provided in UG1165.
