Linux Development
Hello Experts,
I am developing linux for Red pitaya board (Z7010)
I am trying to build Uboot, with all necessory files.
This is the error i get...
  CC      lib/div64.o
  CC      lib/hang.o
  CC      lib/linux_compat.o
  CC      lib/linux_string.o
  CC      lib/membuff.o
  CC      lib/slre.o
  CC      lib/string.o
  CC      lib/tables_csum.o
  CC      lib/time.o
  CC      lib/hexdump.o
  CC      lib/uuid.o
  CC      lib/rand.o
  CC      lib/panic.o
  CC      lib/vsprintf.o
  CC      lib/strto.o
  CC      lib/strmhz.o
  LD      lib/built-in.o
  CC      net/checksum.o
  CC      net/arp.o
  CC      net/bootp.o
  CC      net/eth-uclass.o
  CC      net/eth_common.o
  CC      net/net.o
  CC      net/nfs.o
  CC      net/ping.o
  CC      net/tftp.o
  LD      net/built-in.o
  CC      examples/standalone/stubs.o
  LD      examples/standalone/libstubs.o
  CC      examples/standalone/hello_world.o
  LD      examples/standalone/hello_world
  OBJCOPY examples/standalone/hello_world.srec
  OBJCOPY examples/standalone/hello_world.bin
  LDS     u-boot.lds
  LD      u-boot
arch/arm/mach-zynq/built-in.o:(.data.fpga+0x14): undefined reference to `zynq_op'
cmd/built-in.o: In function `eeprom_rw_block':
/home/yash/linux_yash/u-boot-xlnx/cmd/eeprom.c:149: undefined reference to `i2c_read'
/home/yash/linux_yash/u-boot-xlnx/cmd/eeprom.c:151: undefined reference to `i2c_write'
cmd/built-in.o: In function `do_i2c_reset':
/home/yash/linux_yash/u-boot-xlnx/cmd/i2c.c:1942: undefined reference to `i2c_init'
cmd/built-in.o: In function `do_i2c_probe':
/home/yash/linux_yash/u-boot-xlnx/cmd/i2c.c:987: undefined reference to `i2c_probe'
cmd/built-in.o: In function `do_i2c_crc':
/home/yash/linux_yash/u-boot-xlnx/cmd/i2c.c:768: undefined reference to `i2c_read'
cmd/built-in.o: In function `mod_i2c_mem':
/home/yash/linux_yash/u-boot-xlnx/cmd/i2c.c:863: undefined reference to `i2c_read'
/home/yash/linux_yash/u-boot-xlnx/cmd/i2c.c:911: undefined reference to `i2c_write'
cmd/built-in.o: In function `do_i2c_md':
/home/yash/linux_yash/u-boot-xlnx/cmd/i2c.c:583: undefined reference to `i2c_read'
cmd/built-in.o: In function `do_i2c_read':
/home/yash/linux_yash/u-boot-xlnx/cmd/i2c.c:336: undefined reference to `i2c_read'
cmd/built-in.o: In function `do_i2c_mw':
/home/yash/linux_yash/u-boot-xlnx/cmd/i2c.c:681: undefined reference to `i2c_write'
cmd/built-in.o: In function `do_i2c_write':
/home/yash/linux_yash/u-boot-xlnx/cmd/i2c.c:419: undefined reference to `i2c_write'
/home/yash/linux_yash/u-boot-xlnx/cmd/i2c.c:405: undefined reference to `i2c_write'
cmd/built-in.o: In function `do_i2c_loop':
/home/yash/linux_yash/u-boot-xlnx/cmd/i2c.c:1080: undefined reference to `i2c_read'
cmd/built-in.o: In function `do_thor_down':
/home/yash/linux_yash/u-boot-xlnx/cmd/thordown.c:42: undefined reference to `thor_init'
/home/yash/linux_yash/u-boot-xlnx/cmd/thordown.c:49: undefined reference to `thor_handle'
common/built-in.o: In function `jumptable_init':
/home/yash/linux_yash/u-boot-xlnx/common/exports.c:30: undefined reference to `i2c_write'
/home/yash/linux_yash/u-boot-xlnx/common/exports.c:30: undefined reference to `i2c_read'
Makefile:1495: recipe for target 'u-boot' failed
make: *** [u-boot] Error 1
Could anyone point me to the right direction.
Scholar rfs613
Re: Linux Development
@motagiyash wrote:
I looked the config folder of the red pitaya uboot link you gave. It seems they dont have defconfig file. So I guess i need to create my own . So , as i am bit new to the linux development, do we have a document or guidelines for developing the defconfig file.
The RedPitaya u-boot appears to have a defconfig file (note, this on a branch, not master) here: https://github.com/RedPitaya/u-boot-xlnx/blob/branch-redpitaya-v2016.4/configs/zynq_red_pitaya_defconfig
The repo is quite old (almost 3 years) so I don't know if is current. But, it should be a reasonable starting point.
Scholar rfs613
General instructions for building u-boot are here: https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841973/Build+U-Boot
This looks like a configuration issue - you have zynq-specific code in eeprom_rw_block() that needs I2C support, but it seems I2C support is not enabled. The most likely explanation is that you are not using the correct defconfig.
I suspect you should be using RedPitaya's u-boot repo (https://github.com/RedPitaya/u-boot-xlnx) and it likely contains the correct defconfig.
Yes, last poster is correct here. You will need to update the defconfig:
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841722/ZCU102+Image+creation+in+OSL+flow
Thanks Rfs and stephenm,
Thanks again for the help.
-Yash
You can just pick a defconfig that is closest to your board. for example, if you are using a zynq ultrascale, just use the zcu102 board
Scholar rfs613
Thank you very much RFs and step for the guidence with the link and information.
I was able to build Uboot.(If you have any sugg from where can i learn more about uboot please tag)
Ill get ahead whith my linux development.
wish you good luck.
-Yash
Scholar rfs613
User manual: https://www.denx.de/wiki/view/DULG/UBoot
If you want to dig deeper into u-boot, start with the README: https://gitlab.denx.de/u-boot/u-boot/blob/master/README
There are many more readmes on specific topics in the "doc" directory: https://gitlab.denx.de/u-boot/u-boot/tree/master/doc
