csd
Linux Driver for JESDC IP
 I'm trying to find a linux driver for the JESD204C IP block, but can't seem to find anything. Looking at the generated DT, it produces:
compatible = "xlnx,jesd204c-4.2";
however that compatible string is not handled by any driver in the xilinx linux codebase (in fact a google search for it seems to come up empty as well).
Can someone point me to a driver that handle that IP block?
   Christian.
[newbie error - I accidentally posted this to Xilinx IP catalog forum and can't find a way to move it to this forum so cross-posting here]
sandeepg
Hi @csd ,
As per driver developer you can reuse the same driver but you need to patch driver and device-tree with compatible string to make it work.
Sandeep
sandeepg
Hi @csd ,
Here is the driver wiki page JESD204B but I'm not sure whether same drivers can be used for JESD204C but I can double check for you.
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841739/jesd204b
https://github.com/Xilinx/linux-xlnx/blob/xlnx_rebase_v5.4_2020.2/Documentation/devicetree/bindings/misc/jesd204b.txt
https://github.com/Xilinx/linux-xlnx/tree/xlnx_rebase_v5.4_2020.2/drivers/misc/jesd204b
Sandeep
csd
Hi Sandeep,
 Thanks for the response but I don't believe they are compatible. The register maps between the B and C are quite different, and the driver compatible list is:
static const struct of_device_id jesd204b_of_match[] = {
{ .compatible = "xlnx,jesd204-5.1",},
{ .compatible = "xlnx,jesd204-5.2",},
{ .compatible = "xlnx,jesd204-6.1",},
{ /* end of list */ },
which doesn't include the"xlnx,jesd204c-4.2" compatible that the JESD204C ip generates in the hw config.
Is there any other any other driver, available or planned ?
Also, looking at the driver above, it seems to just provide a sysfs interface into the registers, so it doesn't actually control the jesd204b interface much. Is there some userspace code that goes with that driver?
 Christian.
sandeepg
Hi @csd ,
Sandeep
