Linux I2C Slave mode
Hi there,
regarding the wiki http://www.wiki.xilinx.com/Cadence+I2C+Driver, I2C Slave mode is not yet available.
Does anyone have made some experience or
spent some effort in order to realize the I2C Slave API?
Andreas
Hi Andreas,
I didn't even realize the upstream supported slave mode. Looks like a newer feature.
I'm curious what your use case is for Linux as a slave.  You can look at the Xilinx SDK standalone drivers as they do support slave mode but I've got no experience with Linux as a slave.
John
Hi John,
our Zynq-PS is intended to be a I2C slave towards a HMI front panel.
Except for I2C, the HMI has no further interfaces. Additionally, it's not possible
to add another I2C slave IP in the PL.
Due to this I followed the approach with the Linux I2C slave API, which is indeed relatively new.
https://www.kernel.org/doc/Documentation/i2c/slave-interface
Finally, thanks for your hint about the standalone drivers.
Maybe I can inherit a few lines of code to implement the I2C slave API...
Andreas
