simozz
Mentor
Mentor
Linux I2C driver
I am trying to use PS I2C on an UltraZED SOM, Linux OS, but I can't see any signal on SDA and SCL lines when I try to read or write from it.
The I2C is enabled from Vivado
From petalinux default generated device-tree, I2C0 is linked to I2C1:
in fact, i2cdetect tool detects the I2C controller as i2c0:
The default I2C1 (enabled on Vivado) DT is the following:
		i2c1: i2c@ff030000 {
			compatible = "cdns,i2c-r1p14", "cdns,i2c-r1p10";
			status = "disabled";
			interrupt-parent = <&gic>;
			interrupts = <0 18 4>;
			reg = <0x0 0xff030000 0x0 0x1000>;
			#address-cells = <1>;
			#size-cells = <0>;
			power-domains = <&zynqmp_firmware 38>;
Is it needed to add something more to the device-tree code to work with I2C on PS ?
pinctrl is not declared for it. Could it be the root of the problem ?
Any hint ?
s.
patocarr
Hi @simozz
  I had to add a clock frequency property to the I2C entry in the devicetree, to have the Cadence driver respond properly. Before this, no devices would show up on the i2cdetect -r  command. I did not need the pinctrl.
&i2c0 {
  status = "okay";
  clock-frequency = <100000>;
-Pat
Give kudos if helpful. Accept as solution if it solves your problem.
https://tuxengineering.com/blog
simozz
Mentor
Mentor
Hello @patocarr,
Thanks for the info.
Actually, the i2c status okay and clock frequency are set in pcw.dtsi (automatically included from system-top.dts). I forgot to mention it in my 1st post.
s.
Tags (3)
patocarr
Hi @simozz
  This one should be quite obvious to mention, but I2C needs pull-ups on sda and scl in order to work. Just making sure you've checked it.
-Pat
simozz
Mentor
Mentor
Hello @patocarr ,
Of course I have the pull up resistor on both lines.
s.
