Linux Kernel 3.3 for Zynq will not start
Hi, I've tried to build a 3.3.0 Linux Kernel from Git (http://git.xilinx.com/?p=linux-2.6-xlnx.git;a=shortlog;h=refs/heads/master-3.3), used the wiki description (http://wiki.xilinx.com/zynq-linux). The build succeeded but if I try to start the Dev-Board ZC702, the kernel will not start ... ## Starting application at 0x00008000 ... Uncompressing Linux... done, booting the kernel. ...no more output on serial... Questions: - Do I also have to build a new Device Tree? - Do I have to set the CONFIG_PHYS_OFFSET variable in .config?
Tags (2)
Re: Linux Kernel 3.3 for Zynq will not start
If you are using the fsbl, uboot and devicetree that was included on the SD card, you should be fine. If you are trying to use your own generated fsbl from sdk, you will need to compile the device tree that's included in the git linux. I think that it's located at arch/arm/boot/dts
The 3.3 kernel, from master-3.3 branch, does require that you rebuild the device tree using the device tree for the 702 in the arch/arm/boot/dts dir of the kernel.  There is an incompatability introduced in the interrupt properties.
The wiki doesn't really address the 3.3 kernel since it's a development branch and not supported yet.  It does boot fine on the 702 last time I checked which was recently.
I've rebuilt the device tree and it's working, thanks a lot for your help!
HB
