_bj_
Linux Kernel 4.6, mmc issue
Hi there,
I compiled the Linux Kernel 4.6 from die git repository and the pull request which solves the drm_encoder_init error. After adding the efuse to the devicetree u-boot starts the Kernel.
But the kernel hangs at this message:
mmc0: new high speed SDHC card at address 0001
mmcblk0: mmc0:0001 00000 29.8 GiB
    mmcblk0: p1 p2
mmc0: Timeout waiting for hardware interrupt.
mmcblk0: error -110 transferring data, sector 266312, nr 240, cmd response 0x900, card status 0xb00
With Kernel 4.4.0 everything is working fine. Any ideas?
_bj_
Solution is to get the last commit from the repository. It adds a switch to the devicetree for broken adma sdhci mode. Something goes wrong int he sdhci driver with the adma mode. So you can disable the adma mode with "broken-adma2 = <0x1>;" in the sdhci nodes of the devicetree. Compile the latest kernel and everything is working.
Note: I read that switching to sdma mode is slowing down the card by ~20%
roccobrandi
I have the same rpoblem
_bj_
I want to add that I tested it with the Z-turn Board from MYiR and the Zedboard (both of them using the 7z020 SoC). Each of the boards working fine with the 4.4 Kernel, with 4.6 the kernel is not able to read from the SD-Card.
_bj_
roccobrandi
thanks for the tips!
I have downloaded the lates commit, but I don't know why the kernel doesn't boot, it hangs to message "starting kernel..."
But I managed to make it work with kernel 4.6 too. in the bootargs argument I pass "sdhci.debug_quirks=32832", which is 0x8040: bit 15 (cd-broken) and bit6 (broken-adma) set.
Rocco
jesuslazarosoce
I am experiencing the same issue. The Kernel hangs when starting.
How did you solve this with kernel 4.6?
