Linux Kernel not removing .note.gnu.build-id section
I'm trying to get the Linux Kernel to boot from the compact flash of my ML605 board with no joy even though I can with another application that is based on the XilKernel.  I read that the most common reason for this is that the bootloop gets overwritten at 0x00000000.
An objdump of my simpleImage.xilinx shows that the GNU build-id is present at 0x00000000 and is loaded.
martin@ubuntu:~/xsi_workspace/linux-xlnx$ microblazeel-unknown-linux-gnu-objdump -h  arch/microblaze/boot/simpleImage.xilinx
arch/microblaze/boot/simpleImage.xilinx:     file format elf32-microblazeel
Sections:
Idx Name          Size      VMA       LMA       File off  Algn
  0 .note.gnu.build-id 00000024  00000000  00000000  00001000  2**2
                  CONTENTS, ALLOC, LOAD, READONLY, DATA
  1 .text         00335c40  c0000000  c0000000  00002000  2**4
                  CONTENTS, ALLOC, LOAD, READONLY, CODE
I connected with XMD and confirmed that 0x00000000 contained the .note.gnu.build-id.  I could rst the processor set the PC to 0xC0000000 and run and see that the Kernel would start booting which shows that the ace file I've created should be good.
So I rebuilt the kernel with V=1 to see the output at the linker stage and it looks like it should remove this section, here's the build output:
make -f scripts/Makefile.build obj=arch/microblaze/boot arch/microblaze/boot/simpleImage.xilinx
  cat vmlinux >arch/microblaze/boot/simpleImage.xilinx.unstrip || (rm -f arch/microblaze/boot/simpleImage.xilinx && echo false)
  microblazeel-unknown-linux-gnu-objcopy -R .note -R .comment -R .note.gnu.build-id -O binary  vmlinux arch/microblaze/boot/simpleImage.xilinx
  /bin/sh /home/martin/xsi_workspace/linux-xlnx/scripts/mkuboot.sh -A microblaze -O linux -C none  -T kernel -a 0xC0000000 -e 0xC0000000 -n 'Linux-3.8.0' -d arch/microblaze/boot/simpleImage.xilinx arch/microblaze/boot/simpleImage.xilinx.ub
but when I use objdump the .note.gnu.build-id is still present.
Here's the version of my Microblaze objcopy:
GNU objcopy (crosstool-NG 1.14.1) 2.21.53.20110813
Copyright 2011 Free Software Foundation, Inc.
This program is free software; you may redistribute it under the terms of
the GNU General Public License version 3 or (at your option) any later version.
This program has absolutely no warranty.
Does anyone have any idea as to why this is happening? Is there something in the Kernel configuration I have to set? Is there a command I can run to remove the section just to see if this is why I can't boot linux from the CF?
Many Thanks,
Martin.
Re: Linux Kernel not removing .note.gnu.build-id section
BTW the kernel was checkdout using
git clone git://git.xilinx.com/linux-xlnx.git
Best Regards,
Martin.
UPDATE:
The objcopy is removing the section but the following strip command is putting it back in again.
microblazeel-unknown-linux-gnu-strip -K microblaze_start -K _end -K __log_buf -K _fdt_start vmlinux -o simpleImage.xilinx
I've manually ran the linking stage again but removing the build-id section again in the strip:
microblazeel-unknown-linux-gnu-strip -R .note.gnu.build-id -K microblaze_start -K _end -K __log_buf -K _fdt_start vmlinux -o simpleImage.xilinx
Although the new elf file doesn't have the offending section it hasn't fixed my problem.
Best Regards,
Martin.
I connected with XMD and see that linux has loaded and that PC contains the correct start address.
XMD% rrd
    r0: 0x00000000      r1: 0x00000000      r2: 0x00000000      r3: 0x00000000
    r4: 0x00000000      r5: 0x00000000      r6: 0x00000000      r7: 0x00000000
    r8: 0x00000000      r9: 0x00000000     r10: 0x00000000     r11: 0x0016ad4a
   r12: 0x00000000     r13: 0x00000000     r14: 0x00000000     r15: 0x00000000
   r16: 0x00000000     r17: 0x00000000     r18: 0x00000000     r19: 0x00000000
   r20: 0x00000000     r21: 0x00000000     r22: 0x00000000     r23: 0x00000000
   r24: 0x00000000     r25: 0x00000000     r26: 0x00000000     r27: 0x00000000
   r28: 0x00000000     r29: 0x00000000     r30: 0x00000000     r31: 0x00000000
    pc: 0xc0000000     msr: 0x00000400
but for some reason it's not running, so if I type "con" I get.
RUNNING> XMD% External Interrupt, Processor Stopped at 0xc0000000
So I reset with "rst", setup the PC manually and then stepped through the code a few times to check it's working and then type "con" and linux boots up ok.
Here is how I generated the ace file.
xmd -tcl genace.tcl -opt genace-xilinx-lnx.opts
where opts file contains
-jprog
-hw ./system.bit
-elf ./simpleImage.xilinx
-board ml605
-target mdm
-ace linux.ace
Am I missing something?
