Linux Watchdog on Zynq halts but does not reboot
Hello!
I have a Zynq Z-7045 running Linux. I enabled the Cadence Watchdog Timer and changed the device tree to state:
&watchdog0 {
status = "okay";
reset-on-timeout;
I then test the behavior out by typing
echo s > /dev/watchdog
waiting the 10 seconds required for the timeout. The system times out, but then halts and does not reboot. DONE goes away as expected but INIT is asserted and stays so. The reboot never starts or completes (I guess). The system is set up to boot from QSPI.
I can't seem to figure out why it won't reboot but only halts. Any clues, ideas or solutions would be appreciated
Tags (3)
Hi neil@formidableengineeringconsultants.com
The first think I would check on your situation is to check if the reboot command behaves in a similar way or not. There are some scenarios where the device would not boot again after a reboot (either WDT or software reset).
  1. If the debugger has been attached at some stage it will catch the processor reset vector. Did you try to check with XSDB what is the status of the device? Is any processor running?
  2. It seems you have a custom board with Zynq-7000 device. Did you check the AR#57744, is a typical issue that might end on a similar behavior that you have described.
Ibai
Thanks for your response. It *is* a custom board but reboot works without issue. If  AR#57744 applies wouldn't a standard reboot fail as well?
Yes, that's right it should fail as soon as the QSPI has been configured in 4byte mode at some stage.
I would suggest then to check what's going on with the debugger. Connect XSDB and check if the processor is still running and what is trying to execute.
Ibai
I connected the debugger and both cores are running but they are stuck it the boot code
Core 0
ffffff20: dsb sy
ffffff24: wfe
ffffff28: b -16 ; addr=0xffffff20
Core 1:
ffffff2c: dsb sy
ffffff30: wfe
ffffff34: mvn r0, #15
ffffff38: ldr lr, [r0]
ffffff3c: cmn lr, #212
ffffff40: beq -28 ; addr=0xffffff2c
So, I guess halted but ready to boot and waiting for some interrupt?
