kolpak
Linux Zynq booting from QSPI requires SD-card?
I need to load Linux from QSPI. My board is Zedboard + FMCOMMS4-EBZ. I need to do this without SD-cards. There is my .bif file:
the_ROM_image:
    [bootloader]D:\linux_zynq_flash_test_zed\linux\zynq_fsbl_0.elf
    D:\linux_zynq_flash_test_zed\linux\system.bit
    D:\linux_zynq_flash_test_zed\linux\u-boot-zed.elf
    [offset = 0xF00000]D:\linux_zynq_flash_test_zed\linux\uImage
    [offset = 0x1400000]D:\linux_zynq_flash_test_zed\linux\devicetree.dtb
    [offset = 0x1410000]D:\linux_zynq_flash_test_zed\linux\uramdisk.image.gz
U-Boot successfully load kernel, devicetree and ramdisk but at boot time Linux starts to check filesystem:
Hit any key within 3 seconds to abort filesystem check
And then:
If I need to load Linux from QSPI I still need to use SD-card?
kolpak
savula
Hi @kolpak,
No need of SD card. you can directly boot the Linux from the QSPI flash.
if if is not working then please check this AR#64903  https://www.xilinx.com/support/answers/64903.html
Best Regards,
Srikanth
kolpak
My kernel command line below:
Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
As you can see Linux set root as /dev/mmcblk0p2.
What I have to do to using QSPI as rootfs instead?
terryo
Hi @kolpak,
Can I assume you're not using Petalinux? If you are, please clarify, and also clarify which version.
Do you have a root filesystem written into your flash, or are you wanting to use a ramdisk for the root filesystem?
Terry
kolpak
