Visitor grenoble2007
Linux and IRQ management
I've just managed to install an interrupt service routine (ISR) in a custom driver for Linux
running on a V4FX Xilinx platform.
but it seems that the ISR is called twice when an interrupt appears.
Indeed, the first thing the ISR does is to completely disable interrupts .
But the ISR is called twice:
. I do a printk that prints twice
. the /proc/interrupts counts 2 interrupts  for my device
I tried to stop interrupts by writing zeroes to the IER and GIER registers in the IPIF interface.
I'm also facing strange behaviors with my device has it seems that some reads or writes are
not performed when I expect them.
The device is remaped with the standard ioremap function call.
Are there problems due to cache ?
Is it possible that the PPC cache flushes to my device ???
 I would very appreciate any help !
Stéphane
Re: Linux and IRQ management
You may be seeing a bug in the Xilinx interrupt controller code that we have a patch for going into the mainline.  It's in progress being integrated thru the system, but I'm not sure exactly what release it will be in.
[PATCH] Powerpc: Xilinx: Intc: Fix level irqs which have duplicates
The current code is not handling edge vs level interrupts correctly and  that's why the isr's get called twice.
It's pretty benign is the reason it's gone this long without notice (til a few months ago).
John
