08-01-2017 07:16 AM
I followed all the instructions of ug1165 to run the linux application (LED blinking with IP) on my zynq 702 board, I copied all elf files to Apps folder and changed the permission too but still I am unable to get the output, I can't figure out where I made the mistake.
Please provide me some helpful resource and guidance.
I attached screen shot of error I'm getting.
08-01-2017 11:43 AM
Choose "Xilinx ARM v7 GNU/Linux Toolchain" as the current toolchain in C/C++ Build > Tool Chain Editor under project properties in SDK. It will be Xilinx ARM GNU/Linux Toolchain by default. Build the project again, copy the binaries and try again.
08-01-2017 07:22 AM
i am also facing same problem
08-01-2017 08:06 AM
what does the readelf command produce? It should look like the below. It's possible you are not targeting the correct cross compiler.
# readelf -h linux_blinkled_app.elf
ELF Header: Magic: 7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00 Class: ELF32 Data: 2's complement, little endian Version: 1 (current) OS/ABI: UNIX - System V ABI Version: 0 Type: EXEC (Executable file) Machine: ARM Version: 0x1 Entry point address: 0x833c Start of program headers: 52 (bytes into file) Start of section headers: 4536 (bytes into file) Flags: 0x5000202, has entry point, Version5 EABI, soft-float ABI Size of this header: 52 (bytes) Size of program headers: 32 (bytes) Number of program headers: 9 Size of section headers: 40 (bytes) Number of section headers: 30 Section header string table index: 27
08-01-2017 11:43 AM
08-01-2017 11:34 PM
