Newbie 694917653
Linux boot error on ml510 (chci_hcd driver error)
  I'm trying to get the two USB ports on the ML510 working . I got an .ace file from Roderick Colenbrander, which could get the two ports working.  http://lists.ozlabs.org/pipermail/linuxppc-dev/2009-March/069185.html shows his explorations on .dts file to make the PCI working properly.
  However, when I configured a linux kernel with chci_hcd supported and plugged in a USB disk, the kernel crashed. Here are  the messages:
~ # [   31.409009] Unable to handle kernel paging request for instruction fetch
[   31.488352] Faulting instruction address: 0x00000000
[   31.547732] Oops: Kernel access of bad area, sig: 11 [#1]
[   31.612299] PREEMPT Xilinx Virtex440
[   31.655005] Modules linked in:
[   31.691466] **bleep**: 00000000 LR: c001a4f4 CTR: 00000000
[   31.750841] REGS: c03ddca0 TRAP: 0400   Not tainted  (2.6.31-rc8)
[   31.823745] MSR: 00021000 <ME,CE>  CR: 24000044  XER: 00000000
[   31.893537] TASK = c03b6318[0] 'swapper' THREAD: c03dc000
[   31.956028] GPR00: c001a4bc c03ddd50 c03b6318 00000010 c03ba5e0 000000
366c df804080
[   32.056021] GPR08: c03e0000 00000000 c03e0000 00000001 c03b6528 ffffab78 ffff
0000 ffff4b20
[   32.156015] GPR16: ffff0000 ffff0000 ffff0000 ffff0000 ffffffff 009e7ae0 ffff
0000 00000000
[   32.256008] GPR24: 00000000 00000000 00000f60 c03e47b4 00000007 00000010 c03b
a5e0 00000000
[   32.358087] **bleep** [00000000] (null)
[   32.397696] LR [c001a4f4] xilinx_i8259_cascade+0x54/0x7c
[   32.461204] Call Trace:
[   32.490396] [c03ddd50] [c001a4bc] xilinx_i8259_cascade+0x1c/0x7c (unreliable)
[   32.575801] [c03ddd70] [c0004108] do_IRQ+0x98/0xb4
[   32.633095] [c03ddd90] [c000e9c4] ret_from_except+0x0/0x18
[   32.698721] [c03dde50] [c003afe4] __do_softirq+0xe4/0x138
[   32.763296] [c03dde70] [c0066784] handle_level_irq+0xb8/0x170
[   32.832040] [c03dde90] [c001a4e0] xilinx_i8259_cascade+0x40/0x7c
[   32.903905] [c03ddeb0] [c0004108] do_IRQ+0x98/0xb4
[   32.961199] [c03dded0] [c000e9c4] ret_from_except+0x0/0x18
[   33.026818] [c03ddf90] [c0006fac] cpu_idle+0xcc/0xdc
[   33.086180] [c03ddfb0] [c000172
[   33.146608] [c03ddfc0] [c0385854] start_kernel+0x230/0x2ac
[   33.212211] [c03ddff0] [c0000200] skpinv+0x190/0x1cc
[   33.271568] Instruction dump:
[   33.306985] XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XX
XXXXXX
[   33.399683] XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XXXXXXXX XX
XXXXXX
[   33.492397] Kernel panic - not syncing: Fatal exception in interrupt
[   33.568423] Call Trace:
[   33.597613] [c03ddbd0] [c0005de8] show_stack+0x44/0x16c (unreliable)
[   33.673647] [c03ddc10] [c0034ad4] panic+0x94/0x168
[   33.730929] [c03ddc60] [c000bd44] die+0x178/0x18c
[   33.787195] [c03ddc80] [c00119f0] bad_page_fault+0x90/0xd8
[   33.852809] [c03ddc90] [c000e834] handle_page_fault+0x7c/0x80
[   33.921553] [c03ddd50] [c001a4bc] xilinx_i8259_cascade+0x1c/0x7c
[   33.993419] [c03ddd70] [c0004108] do_IRQ+0x98/0xb4
[   34.050713] [c03ddd90] [c000e9c4] ret_from_except+0x0/0x18
[   34.116338] [c03dde50] [c003afe4] __do_softirq+0xe4/0x138
[   34.180913] [c03dde70] [c0066784] handle_level_irq+0xb8/0x170
[   34.249657] [c03dde90] [c001a4e0] xilinx_i8259_cascade+0x40/0x7c
[   34.321523] [c03ddeb0] [c0004108] do_IRQ+0x98/0xb4
[   34.378815] [c03dded0] [c000e9c4] ret_from_except+0x0/0x18
[   34.444436] [c03ddf90] [c0006fac] cpu_idle+0xcc/0xdc
[   34.503798] [c03ddfb0] [c000172c] rest_init+0x70/0x84
[   34.564225] [c03ddfc0] [c0385854] start_kernel+0x230/0x2ac
[   34.629828] [c03ddff0] [c0000200] skpinv+0x190/0x1cc
[   34.689192] Rebooting in 180 seconds..
   Using Roderick Colenbrander's .ace file, the result will be :
  ~ # [   23.969225] usb 1-1: new full speed USB device using ohci_hcd and address
 2
[   24.354126] usb 1-1: configuration #1 chosen from 1 choice
[   24.422183] scsi0 : SCSI emulation for USB Mass Storage devices
[   29.501795] scsi 0:0:0:0: Direct-Access     Teclast  CoolFlash        8.01 PQ
: 0 ANSI: 2
[   29.621941] sd 0:0:0:0: [sda] 7637374 512-byte logical blocks: (3.91 GB/3.64
GiB)
[   29.725708] sd 0:0:0:0: [sda] Write Protect is off
[   29.782472] sd 0:0:0:0: [sda] Assuming drive cache: write through
[   29.893729] sd 0:0:0:0: [sda] Assuming drive cache: write through
[   29.966115]  sda:
[   30.278727]
[   30.320689] sd 0:0:0:0: [sda] Assuming drive cache: write through
[   30.393134] sd 0:0:0:0: [sda] Attached SCSI removable disk
[   34.084935] usb 1-1: USB disconnect, address 2
  I really don't know what's the problem. Could you help me?
  My .dts file and boot message are in the attachments.
  Thank you!
